TLC5947 with Odroid XU4 Issues
by daheist on Wed Aug 12, 2020 3:01 pm
Hello everyone,
I hope to get some help here as I'm stuck and do not find any useful documentation to get support from.
The setup:
Odroid XU4
Armbian on MicroSD
Adafruit Blinka -> Blinka test .py file works fine
I then tested this code:
import board
import busio
import digitalio
import adafruit_tlc5947
spi = busio.SPI(clock=board.SCLK, MOSI=board.MOSI) (had to add the "L" here as otherwise I had an error, really awkward that this is not documented anywhere ?)
latch = digitalio.DigitalInOut(board.D5) (I used almost anything possible here, using this page: https://wiki.odroid.com/odroid-xu4/appl ... e/gpio/spi
I just saw now that I should have used D13, as my pin was connected on GPIO#21, but why shouldn't it be D21 ? Doesn't make sense too, couldn't find proper documentation, i might be blind though.
tlc5947 = adafruit_tlc5947.TLC5947(spi, latch)
tlc5947[0]=0
I still get voltage at pin 0, and my vibration motor (I use phone-like vibration motors) still vibrates. which makes sense as it still receives 5.13V (using a multimeter).
Does any one of you see something obvious here ? I'll try again tomorrow using the proper D pin, although I'm not sure if I haven't already tested this one. I fear cabling, or worse, soldering issues.
Thank you !
daheist
Re: TLC5947 with Odroid XU4 Issues
by daheist on Sun Aug 16, 2020 5:45 pm
Hi Guys,
May someone from the support team please answer if possible ? I'm really stuck, and can't wrap my head around this.
I tried everything:
Tried using different GPIO pins, for each of them tried all the "names" they could have..
It seems it doesn't matter what I try, I always get 5V output on the TLC pins.
How can I solve this ? What to measure ? Is it possible that the TLC chip is broken ?
daheist
by adafruit_support_bill on Mon Aug 17, 2020 5:47 am
Which pins? Your photos do not show anything connected to the outputs of the board. The pins in the V+ row are the power rail and will always have 5v on them if you supply 5v to the V+ pin.
The adjacent row of pins are the PWM pins and will pulse LOW.
by daheist on Mon Aug 17, 2020 2:08 pm
Thank you for your answer.
You're right, I wasn't clear enough.
When I measure with a multimeter between the signal and V+ I get 5V, which I guess means that I get no pulse at all.
Hope that clarifies.
daheist
by adafruit_support_bill on Mon Aug 17, 2020 2:48 pm
The outputs of these are open-drain and as mentioned above the pulse will be active LOW. So if you are seeing 5v between the signal pin and the V+, you must be getting a high-duty-cycle pulse.
What do you see on the other signal pins?
Another possible issue is that these are not designed for running inductive loads like a motor. Driving a motor without a kickback protection diode could result in damage to the board.
https://learn.adafruit.com/transistors- ... -2998941-9
by daheist on Wed Aug 19, 2020 3:02 am
Thanks for your answer,
So all pins have the same measure, so 5V between pin and its 5V.
I fear I may have damaged the chip then, is there any way I can verify that ?
Thank you !
daheist
by adafruit_support_bill on Wed Aug 19, 2020 6:51 am
If there was damage from inductive kickback, I'd expect it to be confined to just the one pin. What do you see on the signal pins if you connect the /OE pin to 5v?
by daheist on Wed Aug 19, 2020 7:29 am
Just to be sure I test the right thing and don't burn anything in the process
You suggest I connect my Odroid's 5V to the TLC's OE pin ? And then measure between the Channel's V+ and its signal right ?
Thank you !
daheist
by adafruit_support_bill on Wed Aug 19, 2020 7:50 am
Correct. Pulling /OE to 5v should disable the outputs on the signal pins.
by daheist on Sat Aug 22, 2020 6:17 pm
Well I just tested,
I must be doing something wrong I guess, so..
-> I use my initial setup, and then instead of having my 5V from Odroid go to V+ from board I put it towards /OE as you said.
I feel like pulling it to /OE or to nothing would do the same ?
Results show -2V on every pin (so V+ is 0 and signal is at 2V)
FYI, without OE pin plugged, signal seems to be at around 3V and V+ still 0 obviously.)
Does that give us some indications ?
Thanks again for the feedback !
daheist
by adafruit_support_bill on Sun Aug 23, 2020 5:51 am
You need to power the board when you do that. V+ should be a 5v.
by daheist on Sun Aug 23, 2020 6:51 pm
Oww,
So I need to pull the 5V from my odroid to both V+ and /OE ?
Sorry, I'll try again tonight.
daheist
by daheist on Thu Aug 27, 2020 4:50 pm
Can you confirm ?
Again, I don't wanna burn my brand new board :/
daheist
by adafruit_support_bill on Thu Aug 27, 2020 7:38 pm
Yes. You cannot disable the outputs if the board is not even powered up.
It may be too late. You should never apply voltage to an input pin for a board that is not powered. Most chips do not tolerate input voltages that exceed the supply voltage (VCC) and the TLC5947 is no exception. See section 6 of the datasheet:
https://www.ti.com/lit/ds/symlink/tlc5947.pdf
