MAX6675 and 24LC256 conflict
by Volkemon on Mon Aug 16, 2010 1:24 pm
LOVE the 6675 breakout boards. Just what I needed for a project .
Have two running on a duemilanove, reporting temperature to the serial monitor. Works fine:
// this example is public domain. enjoy!
#include "max6675.h"
int thermoDO = 2;
int thermoCS = 4;
int thermoCLK = 3;
  Serial.begin(9600);
  Serial.println("MAX6675 test");
  // wait for MAX chip to stabilize
  delay(500);
  // basic readout test, just print the current temp
   MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
   delay(500);
   Serial.print("  Sensor "); Serial.print(thermoCS - 3);
   Serial.print("  F = ");
   Serial.print(thermocouple.readFarenheit());
   thermoCS ++;
   if (thermoCS > 5 ){
    thermoCS = 4;
    Serial.println(" ");
DO for both to Digital Pin 2, CLK for both on Digital Pin 3, CS for each on pins 4 and 5.
Now, if I add the code to write the data to a 24LC256, it freezes at the "Wire.endTransmission();" command.
#include <Wire.h>
int thermoDO = 2;
int thermoCS = 4;
int thermoCLK = 3;
int Ftemp = 0;
char chipAdress=0x50;
  Serial.begin(9600);
  int Ftemp = 0;
  delay(500);
   delay(500);
   Ftemp = (thermocouple.readFarenheit());
   Serial.print(Ftemp);
   DataSend();
   thermoCS ++;
   if (thermoCS > 5 ){
    thermoCS = 4;
void DataSend() {
   Wire.beginTransmission(chipAdress);
                     //Set up the chip Internal Address Pointer to the desired location
   Wire.send(0x00);  //First  7 bits of the address
   Wire.send(0x00);  //Second 8 bits of the address
   Wire.send(thermoCS - 3);
   Wire.send(",");
   Wire.send(Ftemp);
   Wire.send(",");
   Wire.endTransmission();      // comment this out to stop program from freezing up
I had the void DataSend() code in the main loop before, I isolated it here to try to eliminate the conflict. (Worked to solve a DS1307/24LC256 conflict I had before)
Running this code without commenting out "Wire.endTransmission();" and it returns one temperature reading on the serial monitor, then freezes. Commenting it out, and it runs normally on the serial monitor, and writes nothing to the 24LC256.
I read the MAX6675 libraries, and noted in max6675.cpp "#include <Wire.h>" is commented out, but nothing else obvious to me on why this doesn't work.
Thanks for reading.
Livin' , learnin' , lovin' and laffin'. Thanks for the help!
Volkemon
Re: MAX6675 and 24LC256 conflict
by Volkemon on Mon Aug 16, 2010 1:59 pm
D'OH!!!
Remembering to put Wire.begin(); in the setup sure cured that....
I saw it moments after posting.
Volkemon
