VL53L0X change ranging profiles
by andibar on Tue Aug 25, 2020 11:07 am
I have installed the Adafruit_VL53L0X Library in the Arduino IDE and the example scetch vl53l0x works fine on ESP8266 D1 Mini. Now in the sketch I want to change the range profile to LONG RANGE.
In the sourcecode I found the function configSensor(VL53L0X_Sense_config_t vl_config).
But if I want to call these function, it doesn't work.
In the setup() after lox.begin() it should be possible to call lox.configSensor(VL53L0X_SENSE_LONG_RANGE). But it doesn't work.
VL53L0X_SENSE_LONG_RANGE is unknown. But if the .h is loaded, the enum VL53L0X_Sense_config_t should be known. It is deklared as public.
I tryed to deklare the variable VL53L0X_Sense_config_t vl_config = VL53L0X_SENSE_LONG_RANGE like in the .h file. But VL53L0X_Sense_config_t does not name a type.
How is it possible to change the mode to LONG RANGE or one of the other modes?
How can I call the config function and use the enum type?
regards,
Andreas
andibar
Re: VL53L0X change ranging profiles
by andibar on Wed Aug 26, 2020 6:36 am
Solved...
It's C++ and I have to use the class name. Was my folt.
If you want to change the ranging profile:
create the object global (like in the example):
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
change the profile in the setup():
lox.configSensor(Adafruit_VL53L0X::VL53L0X_SENSE_LONG_RANGE);
regards,
Andreas
andibar
by mtk59 on Thu Aug 27, 2020 10:56 pm
Hi Andreas,
I am trying to do the exact same thing but am also having issues. I followed your solution but I am getting this error message:
Arduino: 1.8.13 (Windows 10), Board: "Adafruit Feather nRF52832, 0.3.2 SoftDevice s132 6.1.1, Level 0 (Release)"
C:\Users\mkurtz\AppData\Local\Temp\arduino_modified_sketch_335351\vl53l0x.ino: In function 'void setup()':
vl53l0x:21:8: error: 'class Adafruit_VL53L0X' has no member named 'configSensor'
21 | test.configSensor(Adafruit_VL53L0X::VL53L0X_SENSE_LONG_RANGE);
vl53l0x:21:39: error: 'VL53L0X_SENSE_LONG_RANGE' is not a member of 'Adafruit_VL53L0X'
exit status 1
Do you know how to solve this?
mtk59
by andibar on Fri Aug 28, 2020 4:48 am
it depends on which library do you have installed.
I installed the newest library with library manager (Version 1.1.0).
The code that works for me on ESP8266:
#include "Adafruit_VL53L0X.h"
VL53L0X_RangingMeasurementData_t measure;
  Serial.begin(115200);
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  Serial.println("Adafruit VL53L0X test");
  if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  /*Ranging Profile:
    VL53L0X_SENSE_DEFAULT
    VL53L0X_SENSE_HIGH_SPEED
    VL53L0X_SENSE_HIGH_ACCURACY
  lox.configSensor(Adafruit_VL53L0X::VL53L0X_SENSE_HIGH_ACCURACY);
  // power
  Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if (measure.RangeStatus != 4) {  // phase failures have incorrect data
    Serial.print("Distance (mm): ");
    Serial.println(measure.RangeMilliMeter);
  } else {
    Serial.println(" out of range ");
Is from the example sketch.
Could you try this out?
regards,
Andreas
andibar
by mtk59 on Fri Aug 28, 2020 9:41 am
Ahh I found the problem for me. I also have the latest version 1.1 for me installed but I had an older version lingering around that I was referencing too by accident. Thanks for the help!
mtk59
