PyPortal Pin 3&4 Uart issues
by ddrboxman on Sun Aug 30, 2020 1:56 am
I have a PyPortal and have wired up an input to pin 4 in an attempt to use it as a uart connection so that I can read midi data. I'm using the Arduino environment and after reading through the docs and looking at the data sheet I believe that this should be the correct configuration.
Uart mySerial (&sercom0, 4, 3, SERCOM_RX_PAD_1, UART_TX_PAD_0);
void SERCOM0_Handler()
  mySerial.IrqHandler();
My current issue is the second any data hits that pin stops the program stops executing.
Hoping someone can get me unstuck, thanks!
(I've also attached my code below)
main.cpp
(2.68 KiB) Downloaded 3 times
ddrboxman
Re: PyPortal Pin 3&4 Uart issues
by mikeysklar on Mon Aug 31, 2020 11:09 am
Hello ddrboxman,
I apologize for not having a more direct solution, but I think that SERCOM0 would not be a good choice to use with the PyPortal (ASAMD51J20). The schematic shows QSPI_DATA lines tied to SERCOM0 which is 8MB of flash storage in this case.
Please take a look at the schematic:
https://cdn-learn.adafruit.com/assets/a ... 1551215147
I'm thinking that SERCOM{3, 4 or 5} might be viable solutions.
mikeysklar
