LIS3DH and using DRDY
by dobbz on Tue Sep 01, 2020 9:28 am
Is the correct way to use this feature that was added to the LIS3DH library as follows:
lis.enableDRDY();
if (lis.haveNewData()) {
  sensors_event_t event;
  lis.getEvent(&event);
My assumptions are:
1) All required ISRs are handled by the library.
2) The function haveNewData just returns true/false. You still have to retrieve the new data using normal methods.
dobbz
Re: LIS3DH and using DRDY
by dastels on Tue Sep 01, 2020 10:14 am
Based on looking at the library source, enabling interrupt(s) simply means that the INT pin on the breakout will generate data ready interrupts which you can then handle. The library does not handle them. The haveNewData() function does a register read to check if data is ready. It's for polling for new data, as opposed to being informed that there is new data via interrupts.
So you'd use one or the other based on your needs.
dastels
cron
