M5Stick-C - what current can the +5V supply?
pthompson509
Post by pthompson509 »
Hi Folks,
I want to run some LEDs off of the M5Stick-C +5V, but I can't find the current limit. Any hints?
Cheers, Peter
adafruit_support_mike
Re: M5Stick-C - what current can the +5V supply?
The ESP32's GPIO pins can deliver about 5mA. That's enough to run a single LED at reasonable brightness.
If you want more power, you'll probably need to use an LED driver with an external power connection:
https://www.adafruit.com/category/866
pthompson509
Thanks for your reply. 5mA from the GPIO should be enough to drive the NeoPixel string, so I'm not worried about that.
What I *AM* worried about is how much current the +5V line can deliver.
