Adjustable breadboard power supply - 2 outputs ?
by tfcroft4 on Tue Aug 24, 2010 4:09 pm
Could the Adjustable breadboard power supply be adjusted to give a Vcc for MCU 5 or 3.3v plus a higher voltage for a set of large 7 seg LEDs hence giving a power supply for a clock with 6 2.5" or 4" 7 segment LEds which might need 7 - 9v
Ted
tfcroft4
Re: Adjustable breadboard power supply - 2 outputs ?
by adafruit_support_bill on Tue Aug 24, 2010 4:53 pm
The breadboard power supply output is selectable between 3.3, 5 and adjustable voltage. But if you power it with the Adafruit 9v regulated adapter, you can tap off the regulated 9v for other uses too.
http://www.adafruit.com/index.php?main_page=product_info&cPath=44&products_id=63
by tfcroft4 on Tue Aug 24, 2010 5:01 pm
So two outputs would be feasible. Say 9v in then 5v and 7v out. Just checking. Thanks.
Ted
tfcroft4
by adafruit_support_bill on Tue Aug 24, 2010 5:14 pm
No. The adjustable supply only has one output. What I am saying is that if you need 5v for the clock and 9v for the seven-segment display, you can feed the breadboard supply with 9v and set it to output 5v for the clock. You can also use that 9v for your 7-segment display.
