CRICKIT Problems with Motor connections ...
sealyon
Post by sealyon »
I seem to be having problems with the Motor connections on my CRICKIT Feather board. I'm just trying to get a DC Motor to turn as a test. Here's the simple code I'm running:
from adafruit_crickit import crickit
crickit.dc_motor_2.throttle = 1.0
I've tried both motor_1 & motor_2, and nothing moves. I also put a meter on the connections and I'm not seeing any output voltage. I have a 5V 5A power supply running my CRICKIT. I'm using the DC Gearbox Motor - "TT Motor" - 200RPM - 3 to 6VDC (#3777). I've verified that the motor moves with straight 5V from my bench supply. This is a new CRICKIT, just got it a couple weeks ago and this is the first time I've started working with it. What might the problem be and how do I further diagnose what the issue is? Appreciate any help. Thanks.
Franklin97355
Re: CRICKIT Problems with Motor connections ...
Post by Franklin97355 »
Which Feather are you using and does it have any errors when you load the code?
sealyon
Post by sealyon »
I'm using the STM32F405 and I'm not seeing any errors.
