breadboard supply
breadboard supply
by graver1 on Thu Aug 26, 2010 6:02 pm
i have just completed the adjustable power supply. it works as designed
> except when i connect power to the 2 position terminal block. no power goes
> through the regulater. When i put power to the powerjack i see the power at
> the 2 position terminal block and through the regulator. power in to the
> terminal block does not go any where on the board. is there something i left
> out?
graver1
Re: breadboard supply
by franklin97355 on Thu Aug 26, 2010 10:12 pm
Seems to me I had the same problem and it was the jack is labeled backwards. Also this is not the correct forum for this type of post.
franklin97355
by graver1 on Fri Aug 27, 2010 11:28 am
I am new to this forum and don't know were to place this problem. I looked at the board and can't see another way to place the jack.
graver1
by adafruit_support_bill on Fri Aug 27, 2010 11:41 am
This forum is fine. It's a supported product. Below is a link to the post franklin97355 was referring to. I don't think you need to move anything, just change the +/- labels on the screw terminals.
http://forums.adafruit.com/viewtopic.php?f=19&t=16392&p=82324&hilit=+breadboard+power+supply#p82324
by adafruit on Fri Aug 27, 2010 11:44 am
(we moved the post for you :) )
by graver1 on Fri Aug 27, 2010 12:29 pm
That solved my problem. I was not comfortable with reversing wires were the marking planly show a + and -. I have let a lot of magic smoke out of a lot of parts and did not want to let it out of this one. Thanks for the friendly help.
graver1
by adafruit on Fri Aug 27, 2010 1:22 pm
the input is diode protected! :)
