Just as a side note, I'm not using CircuitPython but C(++).
Here's a photo.
SGP40 I2C address 0x59 not showing up in scan
- DrCashberg
Re: SGP40 I2C address 0x59 not showing up in scan
- Pins.png (485.8 KiB) Viewed 370 times
- adafruit_support_carter
Thanks. That soldering looks good.
Can you try loading the CircuitPython firmware real quick:
https://circuitpython.org/board/raspberry_pi_pico/
And see if you can repeat the same scan from above.
We don't have any support for C++ usage.
- DrCashberg
The good news is, it worked with CircuitPython, thank you very much.
The bad news is, this escalated (quickly) to become a support ticket for what I'm doing wrong in my C code, which works for all other sensors...
At least I know that the hardware is working, that's great news! Thanks again.
- DrCashberg
Having tried every other I2C pin combination I'm still not able to find the sensor using the C code provided in the Getting started document. The sensor can be detected when using the I2C scan function in CircuitPython, though. Does someone have an idea what I could try to get it to work with my C(++) code? I'm confused as to how this can be language-dependant....
- defiant12
I have the same problem using raspberry pi 3b+
I've checked the signal on the scope and I see an Ack. See attached photo you can see the 0x59 address followed by a read bit and then ACK.
- NewFile68.png (49.02 KiB) Viewed 307 times
- defiant12
Addition: a 68pF between SDA and GND flattened out that little spike before the ack bit. still - no luck.
- ThongLT
I am using the Orange pi zero which running on Linux but CAN NOT scan i2c address SGP40 ( command line on linux is "i2cdetect -y 1" ) but I can scan and find i2c address SHT30 at https://www.adafruit.com/product/2857
i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
- pmcquay
I'm having this issue as well, raspberrypi 3b+, connected the sgp40 with a quiic breakout, so no soldering. i2c works with PMSA003i sensor, so things should be configured correctly.
- pmcquay
I havent tested it, but this suggests that i2cdetect doesnt find this particular sensor: https://github.com/itsnils/Sensirion_SGP40
edit: I've tested this code, it appears to work correctly. My device is not detected, but it seems like it needs some data written to it before it will output anthing.
