Issues with fingerprint sensor 4651 (Grow R503)
by bgdodds on Mon Apr 05, 2021 12:11 pm
Hey everyone, I'm having fun with my fingerprint sensor but it seems to be giving me intermittent problems. I have it wired up to the TX/RX pins of an Arduino Nano 33 BLE. I first loaded the enroll example sketch and enrolled two of my fingers. Then I loaded the fingerprint sketch, and it happily chugs away "No finger detected" until I put my finger to the sensor, and then it tells me the confidence it has in my finger, like expected. However, at some random time after boot, sometimes as quickly as a few seconds, but usually about a minute or two later, I get into a "Communication error" state that I can't recover from.
I've resoldered the connections to the sensor several times to make sure it's not that - and I'm using a breakout board for connection so I didn't have to cut off the 6-pin connector.
Applying movement to the wires doesn't seem to affect it at all, it doesn't induce the communication error, nor stop it from happening.
I've re-added the setup code to the Communication error if loop to try to reinitialize the sensor upon error, and it reports that it can't find the sensor.
Do I possibly have a bad sensor? Is it a shortcoming of the 33 BLE? Any ideas? Many thanks!
bgdodds
Re: Issues with fingerprint sensor 4651 (Grow R503)
by adafruit_support_carter on Mon Apr 05, 2021 1:58 pm
Seems most likely a connection issue at this point. Can you post a photo of your actual setup showing how everything is connected.
by hosam on Tue Jun 08, 2021 11:13 am
hello everyone
I worked on finger print sensor and I want to know if that sensor have sleeping mode or not
and I want to know if there is any special kind of that sensor containing sleeping mode in it
thanks
hosam
by adafruit_support_carter on Mon Jun 14, 2021 11:03 am
@hosam Please start a new topic for your question.
