my module works but when using it my charger never goes to sleep even when the module is empty while it goes to sleep for the other Qi products that I have.
Do you have a solution to this problem?
Kind regards
end of charge 1901
- mikeysklar
Re: end of charge 1901
Based on the product description I would expect this Qi charger to only work properly with your Qi products.
https://www.adafruit.com/product/1901Since its a Qi charger it can only be used with Qi transmitters! If you want a simpler inductive charger, check out our 5V charger set - it isn't Qi compatible but used together it works quite well!
