SerialFTDI TTL-232 USB Cable Compatibility
by jollyto on Wed May 12, 2021 8:38 pm
Does the SerialFTDI TTL-232 USB Cable https://www.adafruit.com/product/70 is compatible with the Adafruit Bluefruit LE UART Friend - Bluetooth Low Energy (BLE)
https://www.adafruit.com/product/2479
jollyto
Re: SerialFTDI TTL-232 USB Cable Compatibility
by adafruit_support_mike on Wed May 12, 2021 11:05 pm
The pinouts are different.
The Serial Cable can plug directly to the header on an FTDI Friend:
https://www.adafruit.com/product/284
but the signals are arranged differently on the BLE UART Friend. You can use jumpers to connect the appropriate signals, but it isn't a straight-across connection.
by jollyto on Thu May 13, 2021 9:38 am
Does the following connections are correct?
LE UART Friend FTDI Serial TTL-232 Cable
(CTS) <---------> (RTS) Green
(TX) <---------> (RX) Yellow
(RX) <---------> (TX) Orange
(Vin) <---------> (5V) Red
(RTS) <---------> (CTS) Brown
(GND) <---------> (GND) Black
jollyto
by adafruit_support_mike on Thu May 13, 2021 10:16 pm
CTS connects to CTS and RTS connects to RTS. Other than that, it looks good.
