BNO085 Accelerometer Scale Factor
by demir on Wed Jun 02, 2021 3:59 pm
What is the scale factor for Accelerometer?
I received raw accelerometer data but how can convert to g?
I received mostly -160,80,4032 accelerometer data as x,y,z when staying stable position; but how can convert it to calculated accelerometer data?
demir
Re: BNO085 Accelerometer Scale Factor
by millercommamatt on Tue Jun 08, 2021 3:44 pm
Which library are you using and it there a reason you are raw ADC values and not the translated values the Adafruit libraries provide?
An you using specific example code? If so, what?
millercommamatt
by gammaburst on Tue Jun 08, 2021 8:03 pm
demir's question was cross-posted in this discussion:
viewtopic.php?f=19&t=179820&p=875668#p875668
gammaburst
by sj_remington on Thu Jun 10, 2021 5:12 pm
If the accelerometer is held still, with any axis perfectly vertical, the acceleration is exactly +/- 1 g along that axis.
Use that fact and the raw data to figure out the scale factor and offset for each axis.
sj_remington
by gammaburst on Fri Jun 11, 2021 3:08 am
No, gravity varies by about 0.7% due to Earth's irregular shape and composition.
Also, Earth's rotation reduces your apparent gravity as you approach the equator.
The Sun's and Moon's positions also have a slight effect (think tides).
gammaburst
by sj_remington on Fri Jun 11, 2021 11:03 am
Correct, but unfortunately, the BNO085 cannot detect those slight variations.
Which is why most people assume exactly 1 g for the purpose of computing MEMS accelerometer scale and offset factors.
sj_remington
by gammaburst on Fri Jun 11, 2021 1:13 pm
The BNO085 (and other similar inexpensive sensors) can easily detect variations of 0.7% of a g.
Take care using rigid words such as "exact", "cannot", and "fact".
A 0.7% error is acceptable for many applications, so your suggested inversion method of calibration would be adequate, and it's easy to do.
gammaburst
by sj_remington on Fri Jun 11, 2021 1:37 pm
Agreed!
When using the BNO085 to measure g at the North or South pole and at the top of Mt. Everest, one would certainly want to take those calibration considerations under advisement.
sj_remington
