What is the scale factor for Accelerometer?
I received raw accelerometer data but how can convert to g?
I received mostly -160,80,4032 accelerometer data as x,y,z when staying stable position; but how can convert it to calculated accelerometer data?
BNO085 Accelerometer Scale Factor
- millercommamatt
Re: BNO085 Accelerometer Scale Factor
Which library are you using and it there a reason you are raw ADC values and not the translated values the Adafruit libraries provide?
An you using specific example code? If so, what?
- gammaburst
demir's question was cross-posted in this discussion:
viewtopic.php?f=19&t=179820&p=875668#p875668
- sj_remington
If the accelerometer is held still, with any axis perfectly vertical, the acceleration is exactly +/- 1 g along that axis.
Use that fact and the raw data to figure out the scale factor and offset for each axis.
- gammaburst
No, gravity varies by about 0.7% due to Earth's irregular shape and composition.
Also, Earth's rotation reduces your apparent gravity as you approach the equator.
The Sun's and Moon's positions also have a slight effect (think tides).
- sj_remington
Correct, but unfortunately, the BNO085 cannot detect those slight variations.
Which is why most people assume exactly 1 g for the purpose of computing MEMS accelerometer scale and offset factors.
- gammaburst
The BNO085 (and other similar inexpensive sensors) can easily detect variations of 0.7% of a g.
Take care using rigid words such as "exact", "cannot", and "fact".
A 0.7% error is acceptable for many applications, so your suggested inversion method of calibration would be adequate, and it's easy to do.
- sj_remington
Agreed!
When using the BNO085 to measure g at the North or South pole and at the top of Mt. Everest, one would certainly want to take those calibration considerations under advisement.
