LCD Backpack Query
LCD Backpack Query
by _phillip on Fri Jun 11, 2021 1:17 pm
I recently tried to use an Adafruit i2C/SPI LCD backpack #292 and ended up breaking the pot. I have another, but do not want to ruin this one as well.
How, exactly, are you supposed to adjust this tiny pot?
Thanks.
_phillip
Re: LCD Backpack Query
by adafruit_support_bill on Fri Jun 11, 2021 1:44 pm
Very gently :).
As you have discovered, these are quite delicate trim-pots. They designed to be compact and intended for only occasional tweaking to fine-tune a circuit. Once the contrast is adjusted on the LCD, you should not need further adjustments.
I typically use a small jeweler's screwdriver and a light touch. Test in both directions. It should rotate freely in at least one. If you feel increased resistance, you are probably at the end-stop. Forcing it beyond the stop will damage the pot.
by _phillip on Fri Jun 11, 2021 1:51 pm
Ok! Very gently is it then. :)
I think there is room for improvement with this backpack. However, I do have one left and would like to get my $$ out of it. I will try not to wreck it this time.
Perhaps I'll get lucky and not have to adjust it at all. Right!
Thanks for your advice.
_phillip
