SCD-30 NACK
Re: SCD-30 NACK
by ssmoss on Tue Jun 15, 2021 1:12 pm
I willing to work with you on this to a point. What are you looking for me to try and what are you anticipating the time to resolution would be? I ask because in one of the previous responses it was stated there might not even be a resolution and I would like to get my project up and running in a timely fashion or I need to start exploring other options.
adafruit_support_carter wrote:At this time it is unknown what is causing the issue. No ETA on resolution (if any).
Given that I am using x86 which is a standard architecture along with the provided code examples I wouldn't have expected something this glaring to not be caught. The SCD-30 isn't a cheap I would have expected that basic functionality worked out of the box much like the BMP388 did.
ssmoss
Re: SCD-30 NACK
by adafruit2 on Tue Jun 15, 2021 1:47 pm
correct, we dont want to promise a solution before we've worked on it! we will be able to know for sure if its resolvable this week
adafruit2
Site Admin
Re: SCD-30 NACK
by ssmoss on Tue Jun 15, 2021 2:00 pm
So by the end of the week we would know that the SCD-30 works with the FT232H? I am fine to wait, provided that if the code change doesn't resolve stuff you are able to overnight replacement parts.
ssmoss
Re: SCD-30 NACK
by adafruit2 on Tue Jun 15, 2021 2:29 pm
try this code
# SPDX-FileCopyrightText: 2020 by Bryan Siepert, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
import board
import adafruit_scd30
import busio
i2c = busio.I2C(board.SCL, board.SDA, frequency=1000)  # uses board.SCL and board.SDA
scd = adafruit_scd30.SCD30(i2c)
while True:
    # since the measurement interval is long (2+ seconds) we check for new data before reading
    # the values, to ensure current readings.
    if scd.data_available:
        print("Data Available!")
        print("CO2:", scd.CO2, "PPM")
        print("Temperature:", scd.temperature, "degrees C")
        print("Humidity:", scd.relative_humidity, "%%rH")
        print("")
        print("Waiting for new data...")
        print("")
    time.sleep(0.5)
adafruit2
Site Admin
Re: SCD-30 NACK
by ssmoss on Tue Jun 15, 2021 2:48 pm
Thanks for the really fast code tweak; this seems to look good:
import time
import board
import busio
print("Temperature offset:", scd.temperature_offset)
print("Measurement interval:", scd.measurement_interval)
print("Self-calibration enabled:", scd.self_calibration_enabled)
print("Ambient Pressure:", scd.ambient_pressure)
print("Altitude:", scd.altitude, "meters above sea level")
print("Forced recalibration reference:", scd.forced_recalibration_reference)
print("")
print("CO2:", scd.CO2)
print("Temperature:", scd.temperature)
print("Relative Humidity:", scd.relative_humidity)
yielded the following output
Temperature offset: 0.0
Measurement interval: 2
Self-calibration enabled: True
Ambient Pressure: 0
Altitude: 0 meters above sea level
Forced recalibration reference: 400
CO2: 584.362548828125
Temperature: 25.194931030273438
Relative Humidity: 46.331787109375
How does this differer compared to the setting up the board with board.I2C()?
ssmoss
Re: SCD-30 NACK
by adafruit2 on Tue Jun 15, 2021 3:00 pm
it slowed down the data transfer
adafruit2
Site Admin
Re: SCD-30 NACK
by adafruit_support_carter on Tue Jun 15, 2021 3:22 pm
Updates are in the 2.2.0 release:
https://github.com/adafruit/Adafruit_Ci ... /tag/2.2.0
But the main enabler here for the FT232H is the slowed down I2C clock rate. See new example also:
https://github.com/adafruit/Adafruit_Ci ... 32htest.py
Re: SCD-30 NACK
by ssmoss on Tue Jun 15, 2021 3:59 pm
Excellent. Thank you committing the fix so quickly. I have been playing with the sensor for the last couple of hours and they both seem to be working as expected.
ssmoss
