INA219 DC Current Sensor
by MidnightSparks on Sun Jun 13, 2021 9:09 am
With a INA219 module, how would the code look to read the DC current from a DC servo motor? I keep writing my code based off the "getCurrent" example sketch in the INA219 library, but I can't figure out how to get the sensor and the servo to work at the same time.
MidnightSparks
Re: INA219 DC Current Sensor
by adafruit_support_bill on Sun Jun 13, 2021 9:24 am
Servo current draw varies widely depending on activity. Assuming that you want to see the current draw when the servo is moving, send a command to the servo, then immediately start reading the sensor.
by MidnightSparks on Sun Jun 13, 2021 9:47 am
That worked! OMG THANK YOU SO MUCH!!! I was stuck on this for over a day now (I feel like an idiot)
(for anyone in the future, I opened the example "getCurrent" code found in the INA219 library and did as "adafruit_support_bill" suggested - In the beginning of the loop(), I told the servo to begin rotating and then checked the serial monitor and sure enough, it works!)
MidnightSparks
