Adjustable Angle: PRODUCT ID: 1257 End to End connection
by bss2692 on Wed Jun 16, 2021 3:05 am
I am looking to have 2 of these angles/pivots, attached together.
One will be attached to the main base, and the pivoting(free?) end, want attached to a SECOND pivot, which is oriented at 90* of the first.
Can you, and if so, HOW, can you attach these two pivots, End to End? the final pivot, will be attached to a final 2020 arm, which will be able to fully articulate, in both X & y axis.
Thanks very much for assistance.
bss2692
Re: Adjustable Angle: PRODUCT ID: 1257 End to End connectio
by adafruit_support_bill on Wed Jun 16, 2021 5:32 am
It is possible, but you would need to fabricate a joiner plate with grooves to match the ridges on the bases. The ridges on the bases are designed to fit into the slots of the 2020 to keep the bracket from rotating around the fixing bolt.
