HI All,
Yes, I ran all the install stuff as issued in 'Adafruit FT232H Breakout' text and everything was working on my Windows 10 system... until:
>>> import os
>>> os.environ["BLINKA_FT232H"]
'1'
>>> import board
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'board'
>>> import digitalio
ModuleNotFoundError: No module named 'digitalio'
What's this? Not a python person, but it seems like I missed something....what would that be?
Any help would be greatly appreciated!
FT232H issue regarding python setup
- jamesbuchanan1220
- mikeysklar
Re: FT232H issue regarding python setup
Do you have multiple python versions installed? Often on Linux (and I realize you are one Windows) people mix up running 'python' versus 'python3' and the installation for all the Adafruit CircuitPython libraries is tied to one versions (either python or python3).
How much was working before as you went through the process. Had you been able to get passed this point?
- jamesbuchanan1220
Thanks for your reply, I got through all of the installation, no problems. It's just the import of board is my first error.
- mikeysklar
Make sure you are using 'python3' when invoking your scripts or via command line so it can find the board library.
If the above does not work let's force adafruit-blinka to reinstall, but I really think it is mistakingly calling "python" instead of "python3" which gets a lot of people.
sudo python3 -m pip install --force-reinstall adafruit-blinka
