I2C encoder (#4991) & seesaw - when do values wrap?
loneboat
Post by loneboat »
I have successfully wired up and am talking to the rotary encoder from here: https://learn.adafruit.com/adafruit-i2c ... ry-encoder
I am using the seesaw library to retrieve the value, and I notice that as I cycle through the values, I get something like this:
Position: 0
Position: -1
Position: -2
Position: 0
Position: 2
Position: 4
Position: 5
Position: 6
Position: 4
Position: 3
Position: 2
Position: 1
Position: -1
Position: -2
Position: -3
Position: -5
Position: -6
Position: -7
Position: -6
Position: -401
Position: -402
Position: -403
Position: -404
Position: -405
Position: -406
I'm wondering at what point this value will wrap over back into positive numbers?
mikeysklar
Re: I2C encoder (#4991) & seesaw - when do values wrap?
Post by mikeysklar »
I think the code has been updated in the last 8 days to make the clockwise rotation a positive value.
Are you running the latest example?
https://github.com/adafruit/Adafruit_Ci ... eopixel.py
# SPDX-FileCopyrightText: 2021 Kattni Rembor for Adafruit Industries
"""I2C rotary encoder NeoPixel color picker and brightness setting example."""
import board
from adafruit_seesaw import seesaw, neopixel, rotaryio, digitalio
try:
    import _pixelbuf
except ImportError:
    import adafruit_pypixelbuf as _pixelbuf
# For use with the STEMMA connector on QT Py RP2040
# import busio
# i2c = busio.I2C(board.SCL1, board.SDA1)
# seesaw = seesaw.Seesaw(i2c, 0x36)
seesaw = seesaw.Seesaw(board.I2C(), 0x36)
encoder = rotaryio.IncrementalEncoder(seesaw)
seesaw.pin_mode(24, seesaw.INPUT_PULLUP)
switch = digitalio.DigitalIO(seesaw, 24)
pixel = neopixel.NeoPixel(seesaw, 6, 1)
pixel.brightness = 0.5
last_position = -1
color = 0  # start at red
while True:
    # negate the position to make clockwise rotation positive
    position = -encoder.position
    if position != last_position:
        print(position)
        if switch.value:
            # Change the LED color.
            if position > last_position:  # Advance forward through the colorwheel.
                color += 1
            else:
                color -= 1  # Advance backward through the colorwheel.
            color = (color + 256) % 256  # wrap around to 0-256
            pixel.fill(_pixelbuf.colorwheel(color))
        else:  # If the button is pressed...
            # ...change the brightness.
            if position > last_position:  # Increase the brightness.
                pixel.brightness = min(1.0, pixel.brightness + 0.1)
            else:  # Decrease the brightness.
                pixel.brightness = max(0, pixel.brightness - 0.1)
    last_position = position
loneboat
Post by loneboat »
mikeysklar wrote:I think the code has been updated in the last 8 days to make the clockwise rotation a positive value.
Oh this isn't about the direction vs the sign of the values (and yes, it works as you stated). My question was about when does a rotation in to -1234, -1235, -1236... wrap back into some positive value (overflow/underflow). I.e. surely I can't get down to negative 9999999^999999?
mikeysklar
@loneboat,
CircuitPython uses unsigned int by default so 65536'ish would be your rotational range unless you want to define a shorter range to reset at.
