I've been evaluating the Adafruit BME680 sensor with a Raspberry Pi Pico and have been trying to compare readings to local weather data. I'm located in Southern California. I ran the sensor for well over 48 hours and also run it 30 min before I want to take measurements. I've noticed the humidity readings are a lot lower than what the local weather data (wunderground.com) reports. When I add an offset variable in the code it somewhat follows the local weather data but not always. This applies for when I take it outside or indoors.
For the temperature, I've noticed it's off 1-2 degrees Fahrenheit when comparing to a thermostat for my home's HVAC. (I suppose that would be expected)
The altitude reading is off 15-20 m at times even when I update with the local sea level pressure for my location using some online weather data.
Is this behavior to be expected or should I be getting better accuracy/performance? When I looked at the adafruit_bme680.py file it seems there is some temperature compensation for the humidity value done in software. I didn't see any compensation for the gas readings but read online that for the pimoroni users of the BME680 they had to compensate the gas reading for humidity.
Also I had read the following description on your site:
"Bosch can measure humidity with ±3% accuracy, barometric pressure with ±1 hPa absolute accuracy, and temperature with ±1.0°C accuracy. Because pressure changes with altitude, and the pressure measurements are so good, you can also use it as an altimeter with ±1 meter or better accuracy!"
For gas measurements in ohms is there anything I might be able to calibrate against easily without using an expensive device or are people typically looking at the ohms reading just for trends/events for a particular environment?
Adafruit BME680 Accuracy Questions
- sj_remington
Re: Adafruit BME680 Accuracy Questions
Use of online data will never be as good as a local calibration.The altitude reading is off 15-20 m at times even when I update with the local sea level pressure for my location using some online weather data.
Most people calibrate an altimeter using the correct altitude and the measured absolute pressure at location. Use those data and the standard atmosphere model to calculate the equivalent sea level pressure. That calibration should be within one meter and be valid for some hours.
- sj_remington
Potentially useful code. Assumes temperature at sea level is 15 Celsius, standard atmospheric "lapse rate".
// MyAltitude
float readAltitude(float abs_Pressure, float sealevel_Pressure) {
float altitude; //meters, pressure in hPa
altitude = 44330.0 * (1.0 - pow(abs_Pressure /sealevel_Pressure, 0.19029495));
return altitude;
// Calculate sea level equivalent pressure
float calc_p0(float myAltitude, float abs_Pressure) {
float p0;
p0 = abs_Pressure / pow((1.0 - ( myAltitude / 44330.0 )), 5.255);
return p0;
- sdrocker
sj_remington wrote:Potentially useful code. Assumes temperature at sea level is 15 Celsius, standard atmospheric "lapse rate".Code: Select all
// MyAltitude float readAltitude(float abs_Pressure, float sealevel_Pressure) { float altitude; //meters, pressure in hPa altitude = 44330.0 * (1.0 - pow(abs_Pressure /sealevel_Pressure, 0.19029495)); return altitude; } // Calculate sea level equivalent pressure float calc_p0(float myAltitude, float abs_Pressure) { float p0; p0 = abs_Pressure / pow((1.0 - ( myAltitude / 44330.0 )), 5.255); return p0; }
Awesome thank you for the code. I found an online calculator that gives the expected sea level for the pressure I measured from the bme680.pressure variable which read 1006 hPa and my known altitude of 99m. The online calculator gives sea level pressure of 1017 hPa with my altitutude and measured pressure. There is a variable called bme680.sea_level_pressure in the Adafruit example which I set to the 1017 hPa and it comes out close. I can fiddle with the value to get the bme.680.altitude to show exactly 99m. I'm not sure if that's one easy way to get the calibration? Basically fiddle with the bme680.sea_level_pressure variable without doing any calculations?
Your code uses the equation in some form in this page where I got the 1017 hpA?
https://keisan.casio.com/exec/system/1224575267
It looks like in the comments section someone wrote out the equation a little more code friendly and it seems to have a variable for temperature:
float p0 = ((pres/100) * pow(1 - (0.0065 * h / (temp + 0.0065 * h + 273.15)), -5.257));
- sj_remington
As stated, in the code I posted, the sea level air temperature is assumed to be 15 C. The code you posted above allows you to enter a different sea level air temperature in C, but what value would you use, and does using a different value make a significant difference?
More on the standard atmosphere formulas here: https://www.mide.com/air-pressure-at-al ... calculator
The second function posted calculates the calibration constant p0, or bme680.sea_level_pressure, which I find to be quicker and more accurate than "fiddling".Basically fiddle with the bme680.sea_level_pressure variable without doing any calculations?
What does that mean? The two lines of code are equivalent and correct, as long as "pres" is a float variable. If it is an integer, then integer division errors will ensue from the expression (pres/100).a little more code friendly
- sdrocker
sj_remington wrote:As stated, in the code I posted, the sea level air temperature is assumed to be 15 C. The code you posted above allows you to enter a different sea level air temperature in C, but what value would you use, and does using a different value make a significant difference?
Thanks. That does make sense regarding the calibration constant p0. The online calculator I shared shows the input values entered at "present location" including the pressure, altitude, and temperature.
I guess I have to think about how useful this sensor is for anything I would be doing. For monitoring pressure you actually want to calculate p0 and use that to get your variations in sea level pressure due to weather changing (ie, pressure changes from high or low system passing through)? Calculating the p0 value to correct the altitude value would be useful if you were going to put this on a drone or something and record the altitude of the drone?
Regarding my comment about the more code friendly.. I mean the person in the comments wrote out the equation in arduino code based on the equation a little bit above in the same page which obviously would need to be written out differently in code syntax.
- sj_remington
You don't need to calibrate a barometer for predicting weather. Just calculate pressure change over time. Rapid drops suggest that a storm front is moving in.
A barometer used as an altimeter must calibrated frequently, sometimes hourly if the weather is changing.
- sdrocker
Thanks. Have you used the BME680 much? I'm struggling with the humidity reading. It seems quite off from what online weather says for my zip code even if I'm inside or outside. I'm noticing the humidity isn't always off my a set amount it seems to vary more during the day. For instance at night it seems to be off by a larger amount than in the morning.sj_remington wrote:You don't need to calibrate a barometer for predicting weather. Just calculate pressure change over time. Rapid drops suggest that a storm front is moving in.
I'm wondering if for air quality I would be better off with the sgp30 and a different humidity, pressure, temp sensor. I was trying to keep the cost in the $18 or under range which is why the BME680 was attractive.
Relative humidity can vary quite a bit over small distances depending on things like temperature and localized sources of water vapor. For example a bathroom will likely measure higher than other rooms. Outdoors, a shady lawn or lakeside will typically measure higher than a parking lot.It seems quite off from what online weather says for my zip code
- sj_remington
I have never found humidity readings to be very useful, and inexpensive sensors are notorious for inaccuracy and misbehaving.I'm struggling with the humidity reading.
Keep in mind that relative humidity depends extremely strongly on air temperature.
- sdrocker
Thanks I'll keep that in mind!sj_remington wrote:I have never found humidity readings to be very useful, and inexpensive sensors are notorious for inaccuracy and misbehaving.I'm struggling with the humidity reading.
- sdrocker
Thanks. Does Adafruit have much experience using this and comparing to other sensors? I guess I just wanted something to compare to but didn't anticipate needing to buy an expensive sensor to calibrate against.adafruit_support_bill wrote:Relative humidity can vary quite a bit over small distances depending on things like temperature and localized sources of water vapor. For example a bathroom will likely measure higher than other rooms. Outdoors, a shady lawn or lakeside will typically measure higher than a parking lot.It seems quite off from what online weather says for my zip code
Another question, I noticed Bosch has the BSEC library to get something useful out of the gas sensor, ie they have a way to translate that to IAQ. I wanted to use this setup in CircuitPython so it's not going to be very useful for me it looks like. I noticed the Adafruit BME library doesn't use humidity compensation for the Gas sensor whereas I had read the BSEC library does. Do you know if that will be implemented in the future? Has anyone at Adafruit used the BME680 and compared to any more expensive sensors to judge the performance?
We have not done any formal head-to-head comparison testing. But I've had good results with both Bosch and Sensirion. Once calibrated, the temperature and pressure compare well against reference sensors.
https://learn.adafruit.com/calibrating-sensors
Humidity and gas sensing technology is more complex and harder to miniaturize. Small low-cost sensors such as the BME680 have been steadily improving. But they are still not in the same league as industrial-grade sensors costing two orders of magnitude more.
As for CircuitPython support, you may want to post your question over on the CircuitPython forum. The CircuitPython development team monitors that pretty closely: viewforum.php?f=60
- sdrocker
adafruit_support_bill wrote:We have not done any formal head-to-head comparison testing. But I've had good results with both Bosch and Sensirion. Once calibrated, the temperature and pressure compare well against reference sensors.
Got it, thanks I'll keep that in mind regarding the temperature and pressure. One thing I noticed using the example CircuitPython script is the sleep (1) in the while loop. If I use that I can see the ohms reading goes up when I start up the device after it's been sitting overnight until it reaches somewhere around 108,000 ohms after maybe 10 minutes. When I change the 1 second delay in the loop to 180, eventually the humidity reading rises and the temperature reading goes down a bit but the ohms value drops down to 7500 or so.
I wonder if it would make sense to sample with 1 second delay when taking gas measurements (after the 10 minute reading stabilization) and then switch to 180 seconds for temp/humidity.
The gas measurement uses a heater internal to the sensor. The sensor will sequence the readings so that the heater doesn't start until after the temperature, pressure and humidity readings are complete. However, with a fast sample rate, it is possible that residual heat from the previous read sequence could affect the humidity and temperature readings. I'd try increasing the delay between samples and see if your results improve.
Reading any single parameter will still trigger the full internal sequence for reading all 4 sensors.I wonder if it would make sense to sample with 1 second delay when taking gas measurements (after the 10 minute reading stabilization) and then switch to 180 seconds for temp/humidity.
