Since no any new thinking about BNO085 with UART : viewtopic.php?f=19&t=181558
I buy a Adafruit MCP2221A Breakout to try BNO085 i2c.
But it still fail...I can't get any data from BNO085 and it return error any one can help?
The board I use : MCP2221
The sample code I use : https://github.com/adafruit/Adafruit_Ci ... pletest.py
The Error message I got.
Use Bno085 with bno08x_simpletest.py fail.
- Wols
Re: Use Bno085 with bno08x_simpletest.py fail.
Sice I use this code, which show on adafruit/Adafruit_CircuitPython_BNO08x/readme, instead bno08x_simpletest.pyWols wrote:Since no any new thinking about BNO085 with UART : viewtopic.php?f=19&t=181558
import board
import busio
from adafruit_bno08x.i2c import BNO08X_I2C
from adafruit_bno08x import BNO_REPORT_ACCELEROMETER
bno = BNO08X_I2C(i2c)
bno.enable_feature(BNO_REPORT_ACCELEROMETER)
while True:
accel_x, accel_y, accel_z = bno.acceleration # pylint:disable=no-member
print("X: %0.6f Y: %0.6f Z: %0.6f m/s^2" % (accel_x, accel_y, accel_z))
I think there has some little thing i should config in bno08x_simpletest.py
I will keep trying.
- adafruit_support_carter
Try running the simpletest again but change this line:
to this:
i2c = busio.I2C(board.SCL, board.SDA, frequency=400000)
- Wols
Still same error :'(
Error message
# SPDX-FileCopyrightText: 2020 Bryan Siepert, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
import board
import busio
from adafruit_bno08x import (
BNO_REPORT_ACCELEROMETER,
BNO_REPORT_GYROSCOPE,
BNO_REPORT_MAGNETOMETER,
BNO_REPORT_ROTATION_VECTOR,
bno.enable_feature(BNO_REPORT_GYROSCOPE)
bno.enable_feature(BNO_REPORT_MAGNETOMETER)
bno.enable_feature(BNO_REPORT_ROTATION_VECTOR)
while True:
time.sleep(0.5)
print("Acceleration:")
print("")
print("Gyro:")
gyro_x, gyro_y, gyro_z = bno.gyro # pylint:disable=no-member
print("X: %0.6f Y: %0.6f Z: %0.6f rads/s" % (gyro_x, gyro_y, gyro_z))
print("")
print("Magnetometer:")
mag_x, mag_y, mag_z = bno.magnetic # pylint:disable=no-member
print("X: %0.6f Y: %0.6f Z: %0.6f uT" % (mag_x, mag_y, mag_z))
print("")
print("Rotation Vector Quaternion:")
quat_i, quat_j, quat_k, quat_real = bno.quaternion # pylint:disable=no-member
print(
"I: %0.6f J: %0.6f K: %0.6f Real: %0.6f" % (quat_i, quat_j, quat_k, quat_real)
print("")
File "c:\Users\canic\Desktop\code\BNO085\BNO085_ada_i2c_mcp2221.py", line 27, in <module>
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_bno08x\__init__.py", line 601, in acceleration
self._process_available_packets()
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_bno08x\__init__.py", line 789, in _process_available_packets
while self._data_ready:
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_bno08x\i2c.py", line 148, in _data_ready
header = self._read_header()
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_bno08x\i2c.py", line 94, in _read_header
i2c.readinto(self._data_buffer, end=4) # this is expecting a header
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_bus_device\i2c_device.py", line 67, in readinto
self.i2c.readfrom_into(self.device_address, buf, start=start, end=end)
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\busio.py", line 149, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_blinka\microcontroller\mcp2221\i2c.py", line 23, in readfrom_into
self._mcp2221.i2c_readfrom_into(address, buffer, start=start, end=end)
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_blinka\microcontroller\mcp2221\mcp2221.py", line 319, in i2c_readfrom_into
self._i2c_read(0x91, address, buffer, start, end)
File "C:\Users\canic\AppData\Local\Programs\Python\Python39\lib\site-packages\adafruit_blinka\microcontroller\mcp2221\mcp2221.py", line 289, in _i2c_read
raise RuntimeError("I2C read error: max retries reached.")
RuntimeError: I2C read error: max retries reached.
Not sure. The BNO085 is a tricky sensor. And the MCP2221 has its own quirks. So the combo just seems to not be working. Opened an issue for this here:
https://github.com/adafruit/Adafruit_Ci ... /issues/28
