MPR121 Touch Sensor communication problems
Lucas79
Post by Lucas79 »
Hi!
A while ago I've posted something about the MPR121 board. After founding some interesting things here, I've bought 2 of them. I was able to configure them inside the code of the firmware that allows to communicate with the hub, hence everything works. But, sometimes I get a really weird behaviour, and after I've to reset the MCU (an Arduino Nano IoT).
What happens, more in detail, is this:
- the communication works for a while without problems
- after an undefined amount of time it starts to "slow" down a bit (touching one or more buttons generates no events)
- after some seconds the board responds with a touch event on all the buttons (even the ones that aren't connected with a sensor)
- after this the board is totally unresponsive
The active buttons, just 7, are connected to a large touching surface (around 6cm x 6cm). In this way, with the configuration that I've found on this post, I can sense a touch through a wide surface (around 2,5cm). The firmware the runs Arduino, apart the one to communicate with the MPR121, is instead here.
Has anyone a suggestion about a possible cause of this behaviour? How can I slow down the communication with the MPR121?
mikeysklar
Re: MPR121 Touch Sensor communication problems
Post by mikeysklar »
@BANNED,
You can slow down the i2c connection on Arduino code using the WireSetClock() function.
I would start with setting the i2c speed at 100kHz which is "standard" mode. You can go even lower if necessary.
https://www.arduino.cc/en/Reference/WireSetClock
