Macropad non-ascii character sequence
- kayaking_t
I'm wondering if anyone has created a macro for using non-ascii spanish characters like ñ (alt+0241) and ¡ (alt+0161) as key presses on the Macropad. I use these characters all the time and always forget when the alt coding is for them. Also, I'm noticing that these special characters aren't showing on the display of the Macropad. I'm currently using the Project Bundle from the Macropad Hotkeys adafruit learn guide (https://learn.adafruit.com/macropad-hot ... igurations). Thanks in advance.
- kayaking_t
Re: Macropad non-ascii character sequence
I did figure out how to setup the typing of the alt codes, but I'm still unable to get the actual non-ascii character to show correctly on the display. If there is a way of changing it to work, let me know. I had to setup release of the keycodes as well. Here's my circuit python code (it has both emoji's and spanish alt codes).
# MACROPAD Hotkeys example: Universal Numpad
from adafruit_hid.keycode import Keycode # REQUIRED if using Keycode.* values
app = { # REQUIRED dict, must be named 'app'
'name' : 'español & emoji', # Application name
'macros' : [ # List of button macros...
# COLOR LABEL KEY SEQUENCE
# 1st row ----------
(0x202000, '~n', [Keycode.ALT,
Keycode.KEYPAD_ZERO, -Keycode.KEYPAD_ZERO,
Keycode.KEYPAD_TWO, -Keycode.KEYPAD_TWO,
Keycode.KEYPAD_FOUR, -Keycode.KEYPAD_FOUR,
Keycode.KEYPAD_ONE, -Keycode.KEYPAD_ONE,
-Keycode.ALT]),
(0x202000, "'a", [Keycode.ALT,
Keycode.KEYPAD_FIVE, -Keycode.KEYPAD_FIVE,
-Keycode.ALT]),
(0x202000, '?', [Keycode.ALT,
Keycode.KEYPAD_NINE, -Keycode.KEYPAD_NINE,
-Keycode.ALT]),
# 2nd row ----------
(0x202000, '~N', [Keycode.ALT,
-Keycode.ALT]),
(0x202000, "'A", [Keycode.ALT,
Keycode.KEYPAD_THREE, -Keycode.KEYPAD_THREE,
-Keycode.ALT]),
(0x202000, '!', [Keycode.ALT,
Keycode.KEYPAD_SIX, -Keycode.KEYPAD_SIX,
-Keycode.ALT]),
# 3rd row ----------
(0x202000, 'ohms', [Keycode.ALT,
-Keycode.ALT]),
(0x202000, 'Tongue', [':p', Keycode.SPACE]),
(0x202000, 'wink', [';)', Keycode.SPACE]),
# 4th row ----------
(0x202000, 'straight', [':|', Keycode.SPACE]),
(0x202000, 'sad', [':(', Keycode.SPACE]),
(0x202000, 'happy', [':)', Keycode.SPACE]),
# Encoder button ---
(0x000000, '', [Keycode.BACKSPACE])
- SolderMask
This looks great, but I can't get your code to work. Did a copy and paste, saved it, but it does not show as a viable macro when I turn the encoder.
Anyone else get it to work? Or found a fix?
- kayaking_t
Not sure what to suggest. I do have the entire contents of my Macropad up in github if that would help: https://github.com/AndNotOr-Designs/macroPadSolderMask wrote:This looks great, but I can't get your code to work. Did a copy and paste, saved it, but it does not show as a viable macro when I turn the encoder.
- SolderMask
Thanks @kayaking_t,
I downloaded your files as a zip. I didn't see a ***.uf2 file (figured it was pretty essential) so I tried it with and without that file. Got the red error blink in LED #1 and the screen looks to say:
KER_ENABLE
Code done running.
I'm wondering if you are using a vastly different version of the main ***.uf2 file and that is causing things to act differently?
I'm running adafruit-circuitpython-adafruit_macropad_rp2040-en_US-7.0.0-alpha.5.uf2
I love that you added MP3 files- presumably to announce which macro you are switching to? I'll dive into your code.py and macros to see if I can learn more on how you got these to work.
Kind regards!
KER_ENABLE
Code done running.
Kind regards!
- kayaking_t
I followed the instructions on the .uf2 file from the instructions here: https://learn.adafruit.com/macropad-hot ... cuitpythonSolderMask wrote: I'm wondering if you are using a vastly different version of the main ***.uf2 file and that is causing things to act differently?
Yes, it's set so that I can not have to look at the keypad to know what screen I'm on for the hot keys. I do have to modify the order as it is a bit out of order right now, I just haven't had the time...SolderMask wrote: I love that you added MP3 files- presumably to announce which macro you are switching to? I'll dive into your code.py and macros to see if I can learn more on how you got these to work.
Kind regards!
- kayaking_t
Order is fixed now and GitHub is updated. Happy coding!kayaking_t wrote: I do have to modify the order as it is a bit out of order right now, I just haven't had the time...
- SolderMask
I got it to work-kayaking_t wrote: I followed the instructions on the .uf2 file from the instructions here: https://learn.adafruit.com/macropad-hot ... cuitpython
I forgot that I had to go into bootloader mode (as pointed out in the URL you sent). I updated the .uf2 file (I was running the Alpha version)... makes sense that it has to be using the correct OS version.
Figured I'd spell this out, should someone else end up in the same boat as me. Thanks for the help!
On a side note, if someone knows, should another version come along, is there a way to have a checksum built into the code.py file to let you know there is a version conflict (as in, the code.py was written for 7.0.0 and someone is running a different version, unaware?)
- kayaking_t
That's GREAT to hear! Thanks for letting me know. I'm really new to this avenue of programming, so I'm definitely NOT the one to ask about checksums...SolderMask wrote: I got it to work-
Happy coding!
