Adifruit sesaw.h
Megakbyrne
Adifruit sesaw.h
Post by Megakbyrne »
I have tried every resource available to obtain a library for my soilmoisture sensor bought from adifruit and I need help obtaining it for my two sensors. Any help in the right direction would be appreciated. soilmoisture sensor.
adafruit_support_carter
Re: Adifruit sesaw.h
The guide here:
https://learn.adafruit.com/adafruit-ste ... r/overview
shows how to use with CircuitPython or Arduino.
The CircuitPython library is here:
https://github.com/adafruit/Adafruit_Ci ... hon_seesaw
The Arduino library is here:
https://github.com/adafruit/Adafruit_Seesaw
Megakbyrne
This is the error message that I still get. It vas compiled in word pad.
Adifruit Seesaw Error Messaget.pdf
(25.78 KiB) Downloaded 2 times
You're missing a library dependency. But also, you have multiple copies of the seesaw library installed. I'd suggest manually deleting these folders:
C:\Users\User\Documents\Arduino\libraries\Adafruit_Seesaw
C:\Users\User\Documents\Arduino\libraries\Adifruit
C:\Users\User\Documents\Arduino\libraries\Adafruit_Seesaw-master
and then reinstall the seesaw library. Be sure to install it via the Arduino IDE's Library Manager. That way, any library dependencies will also be installed at the same time.
Megakbyrne
Thank you. I will try that out today and reply with results.
Megakbyrne
Adifruit Soil Sensor.pdf
(25.34 KiB) Downloaded 3 times
I did as you said and first error is fixed. Now I nee a file called Adafruit_12Cdevice.h
Any help would be appreciated + a pdf on bread boarding the same.
When you re-installed the Seesaw library via the Arduino Library Manager, did you see this pop up?
Megakbyrne
No I did not see seesaw in library manager. I installed via zip folder method. Will go back and try too input that library file today.
Megakbyrne
Yea, with your continued help I have a sketch ready to try out? Will any 12C LCD screen work or only one bought at Adafruit?
You can try using the library with other products, but Adafruit only supports usage with the ones from the Adafruit shop.
You can also fork the library and modify it however you want.
If you install Arduino libraries via a zip file, you need to take care of dependencies on your own as well. Installing via Library Manager is recommended for that reason.
Megakbyrne
Can you provide me with a link for the right LCD screen?
Here's a link to all LCD like displays:
https://www.adafruit.com/category/63
Not sure what a "12C LCD" is. If that's "character", then here's a link to those:
https://www.adafruit.com/category/96
Or are you looking at a specific guide or something else that mentions a specific display?
Megakbyrne
No I am looking for a guide that uses a specific LCD display for learning purposes. They mentioned a display in adifruit pdf post also.
Can you link to this. Can take a look and see what display they are referring to.
There are Learn guides linked from the bottom of product pages. So you could look for a display you are interested in and then follow those links to the associated learn guide. Like this one for LCD character displays:
https://learn.adafruit.com/i2c-spi-lcd-backpack
Megakbyrne
Thank you for that link. I now have a soil moisture sketch with a LCD screen but I want adafruit due to it being better than China types.
Capacitive is supposed to be better over time.
