2.4" TFT FEATHERWING AND MLX90640 software
alainsam
Post by alainsam »
I am trying to adapt the MLX()640 cam to the 2.4" TFT FEATHERWING. using the AMG88xx GridEYE software as an example.
I get a problem with the interpolation, my program doesn't find the following :
undefined reference to `get_point
Is there an include lib to do the interpolation?
MLX90640TFTDisplay.txt
(8.22 KiB) Downloaded 3 times
MLX90640TFTDisplay_output.txt
Sketch and output
(260.09 KiB) Downloaded 4 times
adafruit_support_mike
Re: 2.4" TFT FEATHERWING AND MLX90640 software
The function interpolate_image() lives in one of the AMG88xx examples:
https://github.com/adafruit/Adafruit_AM ... nterpolate
For the MLX90640, try using the code for the breakout with a built-in display:
https://learn.adafruit.com/mlx90640-the ... g/overview
alainsam
Post by alainsam »
in which directory should I put the interpolation.cpp file? It doesn't seem to work in the directory of my sketch.
That's where any project-specific external code should live.
Do you get separate tabs for the main sketch and the interpolaton code when you open the project in the Arduino IDE?
alainsam
Post by alainsam »
Yes I have both tabs and compilation does not show any error, the monitor display the temperature values but the display stays black.
[The extension ino has been deactivated and can no longer be displayed.]
That means things are probably working on the software side, so let's check the hardware side.
alainsam
Post by alainsam »
I do not see any problem with the hardware tft and cam work with test software and the connections are correct...
I don't see anything out of order there.
Drop back to the test code for the TFT Featherwing:
https://learn.adafruit.com/adafruit-2-4 ... phics-test
Does that work?
alainsam
Post by alainsam »
Yes, the graphictest_featherwing example works fine.
Since I get the temperatures display for the MLX90640, I wonder if my sketch part for the interpolation is correct, but I do not see an error on it?
If the hardware works and the demo code works, the problem has to be in the code that doesn't work. Not seeing the error is different from knowing there are no errors.
Make a copy of the working demo code and modify that to what you're doing with the code that doesn't work. Move in small steps, and test the code after each change to make sure it works. That way any problem that makes the code stop working will always be in the latest change from a working version.
