I'm using a MCP9601 with a Raspberry Pi 400 to try to measure some temperatures.
On the good side, the power light on the board lights up and it detects when I run i2cdetect -y 1. On the bad side it only does this once and won't detect again UNLESS I disconnect and reconnect power to the MCP9601 and reconnect it. If I do that it detects again, once. Any ideas?
MCP9601 & Raspberry pi 400 detects once then doesn't detect
- rrkappes
- adafruit_support_carter
Re: MCP9601 & Raspberry pi 400 detects once then doesn't det
Are you using one of the breakouts?
https://www.adafruit.com/product/5165
How is it connected to the Pi 400?
- rrkappes
- rrkappes
The breakout board is soldered to a header and the pins are installed into a breadboard. From there I'm using jumper wires to connect it to the appropriate pins on a T-cobbler which is connected via a ribbon cable to the Pi 400. I tried connecting a second one via a Stemma QT cable and using one of the address pins to set the address to 0x60. In that case both detect the first time and then don't usually detect until power drops. However, occasionally on or the other will show up after multiple attempts.
I also wired the breakout directly to some jumper wires and connected them to the ribbon cable directly (It was what I had on hand) and I got the same result.
OK, that sounds fine. Some sensors can do weird things when scanning. What if you ignore the scan behavior and just try using the sensor as shown here:
https://learn.adafruit.com/adafruit-mcp ... -3101130-4
Does it work OK in general?
- rrkappes
No. When trying to use the python sample code I either get error 121 (remote IO error) or a no I2C device found error 67. The error also occurs with a Raspberry Pi 4, so I suspect it's either a problem with my wiring or the breakout board itself.
OK, might be connection related then. Can you post a photo showing your setup with the MCP9601 connected to the Pi 400.
- rrkappes
Here's the setup. I have two boards connected, but the issue exists with one or two boards.
Thanks. I'm thinking this might be a soldering issue. By any chance, did you get one of these STEMMA QT cables?
https://www.adafruit.com/product/4209
- rrkappes
I've ordered one. I'll know if that solves it soon.
OK, thanks. If you're willing to wait until it arrives then we can pick this up then. Having that cable will let you go directly from the breakout's STEMMA QT connector to the T-cobbler and remove any soldering issues from the mix.
Let us know what happens!
- rrkappes
Welp. I decided to try another library and found that once I corrected it to support the 9601 (by adding support for the 9601 chip ID of 0x41) to the library located here I get good functionality out of the chip.
https://pypi.org/project/mcp9600/
I looked at the adafruit library and it appears to have added support for this already, but it still doesn't work on the breakout board, so obviously something subtle is going on. As it stands, I'll be able to do what I need to using this other library, but I still want to understand why the adafruit library isn't working for me.
EDIT: A previous version of this post included a link to the wrong library
