Stema QT without the cable
daque
Post by daque »
by daque on 14 Sep 2021 12:48
So (BME280) on a 3.3v only bus just hook wire Vin and 3va to 3.3v and use only gnd, sck, and sd0? Do not connect sd1 and cs?
May be moved to soldered breadboard after it works is why I’m not using the cable.
dastels
Re: Stema QT without the cable
Post by dastels »
Connect power to Vin ONLY. The 3v pin is the output of the onboard 3.3v regulator. Other than that, yes, ground to GND, I2C's SCL to the SCK pin, and SDA to the SDI pin. As detailed at https://learn.adafruit.com/adafruit-bme ... -2958097-2.
daque
Post by daque »
Thank you!
