DT71 tweezer volt meter not functioning
funkfinger
Post by funkfinger »
Hi, Having issue like this: viewtopic.php?f=19&p=882766
The device does not show up when plugged into my computer.
While plugged in to the charger, the screen reads
DFU:V3.53
5.214V
Followed what I could on the enclosed issue but to no avail.
The screen turns on in the charger, but does not turn on in the tweezers.
The tweezers charged all night, and the red light never turned off.
The order number is #2658144-0123715368
mikeysklar
Re: DT71 tweezer volt meter not functioning
Post by mikeysklar »
Do you have a known good USB data cable?
I've seen these tweezers do well with a factory reset which would require a working USB data cable for the mounting and upgrade of FW.
https://www.minidso.com/forumdownload/D ... 20V1.1.pdf
funkfinger
The device doesn't show up when plugged into USB on both my Mac and PC so I can't update that file
mikeysklar
My question about your the USB cable still remains. Are you using a known good USB data cable that you use with other microcontrollers or storage devices to transfer data?
funkfinger
Yes, I unplugged the keyboard I am typing on and tested. The device did not mount.
mikeysklar
Okay, let's set you up with a return or refund. Please e-mail [email protected] with your preference. Include your order# and a link to this forum thread as proof of troubleshooting.
