Spools of power cable
- KJ7RRV
Does Adafruit sell spools of a cable similar to the one used in https://www.adafruit.com/product/743 ?
- mikeysklar
Re: Spools of power cable
We do not sell spools of waterproof cable.
We do have a lot of 2.1mm barrel jack connectors that you could use make your own cables using silicon cover stranded cable.
https://www.adafruit.com/?q=2.1mm+barre ... =BestMatch
https://www.adafruit.com/?q=silicon+cov ... =BestMatch
- KJ7RRV
Okay, thank you!
Do cables need to be rated as weatherproof to be safe to use outside? Specifically, I'm thinking of cutting the ends off https://www.adafruit.com/product/993 and using it as an outdoor power cable. It will be carrying 12 volts at about 300 mA.
- mikeysklar
Weatherproof cables are a good idea if it will be exposed to the elements (sunlight and rain). Normally you would want to use conduit as a layer of protection to ensure any outdoor cable holds up. If the cable can be mounted under an awning or porch that can help a lot.
You USB cable you selected with custom ends could work fine as long as it is not directly exposed to moisture / sun.
