Teensy Micromod with ADAFRUIT MICRO SD SPI OR SDIO CARD BREA
- bvernham
DEV-16402.
I designed a board that goes below the ATP board using SDIO interface. The ATP board has a native 3.3V regulator. VIN is 5V. In this case I have always been using the USB cable to power both. Same can be said for the Teensy 4.1
[attachment=0]SD capture.JPG[/attachment
So essentially I can run the identical code on the two boards using the same SD card.
For the Teensy 4.1 I am always getting data stored.
For the Micromod with the SDIO interface sometimes yes, sometimes no. The file says it is open but noting gets written to it. The file name shows up but not date and time Seems random. I have run the SDFat bench marks and get identical results. Two boards, same SD card.
Any ideas how to fix this? Detect this is happening so something can be reset? Has anyone experienced the same thing?
Any ideas would be appreciated.
Bruce
