Trying to run Arduino MLX90640_simpletest on FeatherS2 via Stemma cable. The FeatherS2 recognizes the MLX90640 and outputs the ascii matrix but only the lowest readings (all &). The MLX90640 runs on my QtPy . That is my likeness in the output! I know the FeatherS2 is not your board but hoping someone could point me in the right direction. I noticed the serial is not the same between the outputs and neither are the resolution and rate. Ran it with the float output and every other line is nan.
QtPy:
Adafruit MLX90640 Simple Test
Found Adafruit MLX90640
Serial number: 928F924189
Current mode: Chess
Current resolution: 18 bit
Current frame rate: 2 Hz
x+******************************
x+*********++*******************
x+***********+******************
+********++++x+++***************
+*******++xx%xxx++**************
+*******++x%%%xx+***************
+*******++%#%#%x+***************
********+x%%%xxx+***************
*******++x%%#%%%+***************
*******++x#####%+***************
********+x######+***************
********+x%%%%%%+***************
********+x%%x%%%+***************
****++xx%%##%%%%+++*************
***+xxx%%%##%#%%xx+x************
**+x%%%%%%######%%%xxx+*********
++xx%%%%%%%#####%%%%xx++********
xx%%%%%%%%%%%%%%%%%%%%xx++****++
xx%%%%%%%%%%%%%%%%%%%%%%xx++++++
FeatherS2:
Outlier pixels: 5
Serial number: 8BE899F
Current mode: Interleave
Current resolution: 16 bitQt
Current frame rate: 0.5 Hz
MLX90640 bad output on FeatherS2 but good output on QtPy
- rrace001
- adafruit_support_carter
Re: MLX90640 bad output on FeatherS2 but good output on QtPy
What version of the ESP32 Arduino BSP are you using?
- rrace001
esp32 by Espressif Systems version 2.0.0 on Arduino 1.8.15.
Try reverting to the 1.0.6 release of the ESP32 BSP.
- rrace001
Unfortunately the FeatherS2 is not included in the previous versions. I just tried the Sharp memory display (SPI) and it too does not work on the Feather S2 but does on the QtPy. I did get the FeatherS2 to host a web page so not a complete failure. Anyway, thanks for responding. I will write to UM to see what they say.
Thanks. That's probably best. This is most likely an issue with the ESP32 BSP. Not UM's responsibility, but working directly with them will be more efficient.
