TPL5110 breakout board
- fieldifhats70
Hello, I'm looking for a small timer to auto shutoff a circuit (something like turn it on, then auto shutoff after a minute or 2), around 3v (button battery). Can I do this with a TPL5110, or can you suggest another product? Thank you, brian
- mikeysklar
Re: TPL5110 breakout board
Brian,
The TPL5110 or TPL5111 are the right solutions. You just need to decide if you want to use an ENable pin (TPL5111) or want to break the power input TPL5110.
We also have a TPL5110 breakout, which rather than setting an enable pin high/low, connects and disconnects power. The TPL5111 breakout is best when you have an enable pin you can control, the TPL5110 is best when you are able to 'break' the power input line to place the TPL5110 between the power supply and Vin.
