I'm having issues with the Adafruit LTR390-UV. I'm using it with a Raspberry Pi Pico and the Arduino IDE interface. I have the SDA connected to the GP0 and SCL to the GP1 pin. When I run this setup in the CircuitPython environment and the example along with correct configuration of the pins it works perfect. When I try this with the Adafruit Arduino example it doesn't get past the "Couldn't find LTR sensor!" part. When I temporarily disconnect the jumper cables and plug in the SHTC3 sensor with the SHTC3 example code it works perfectly so I know it's not a problem with the hardware or the Rapberry Pi working in the Arduino environment.
Here is my CircuitPython code which worked perfectly:
# SPDX-FileCopyrightText: 2021 by Bryan Siepert, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
import busio
import board
import adafruit_ltr390
myI2C = busio.I2C(scl=board.GP13, sda=board.GP12)
ltr = adafruit_ltr390.LTR390(myI2C)
while True:
print("UV:", ltr.uvs, "\t\tAmbient Light:", ltr.light)
print("UVI:", ltr.uvi, "\t\tLux:", ltr.lux)
time.sleep(1.0)
Here is how I have the SHTC3 configured which worked perfectly with the GP0, GP1 setup when I wanted to make sure the GP0 and GP1 pins were at least configured correctly in the Arduino IDE:
This is an example for the SHTC3 Humidity & Temp Sensor
Designed specifically to work with the SHTC3 sensor from Adafruit
----> https://www.adafruit.com/products/4636
These sensors use I2C to communicate, 2 pins are required to
interface
#include "Adafruit_SHTC3.h"
#include <Wire.h>
TwoWire Wire_00(i2c0, 0,1); // SDA, SCL for TMP102
Adafruit_SHTC3 shtc3 = Adafruit_SHTC3();
Serial.begin(9600);
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("SHTC3 test");
if (! shtc3.begin(&Wire_00)) {
Serial.println("Couldn't find SHTC3");
while (1) delay(1);
Serial.println("Found SHTC3 sensor");
sensors_event_t humidity, temp;
shtc3.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
delay(1000);
Here is what my LTR390 code looks like and I configured the GP0 and GP1 similar to how I had done for the SHTC3 however this is not making it past the "Couldn't find LTR sensor!" part of the code.
This is an example for the LTR390 UV Sensor
Designed specifically to work with the LTR390 UV sensor from Adafruit
interface
#include "Adafruit_LTR390.h"
#include <Wire.h>
TwoWire Wire_00(i2c0, 0,1); // SDA, SCL for Afafruit LTR390
Adafruit_LTR390 ltr = Adafruit_LTR390();
delay(10000);
Serial.begin(9600);
Serial.println("Adafruit LTR-390 test");
Wire_00.begin();
if ( ! ltr.begin(&Wire_00) ) {
Serial.println("Couldn't find LTR sensor!");
while (1) delay(10);
Serial.println("Found LTR sensor!");
ltr.setMode(LTR390_MODE_UVS);
if (ltr.getMode() == LTR390_MODE_ALS) {
Serial.println("In ALS mode");
} else {
Serial.println("In UVS mode");
ltr.setGain(LTR390_GAIN_3);
Serial.print("Gain : ");
switch (ltr.getGain()) {
case LTR390_GAIN_1: Serial.println(1); break;
case LTR390_GAIN_3: Serial.println(3); break;
case LTR390_GAIN_6: Serial.println(6); break;
case LTR390_GAIN_9: Serial.println(9); break;
case LTR390_GAIN_18: Serial.println(18); break;
ltr.setResolution(LTR390_RESOLUTION_18BIT);
Serial.print("Resolution : ");
switch (ltr.getResolution()) {
case LTR390_RESOLUTION_13BIT: Serial.println(13); break;
case LTR390_RESOLUTION_16BIT: Serial.println(16); break;
case LTR390_RESOLUTION_17BIT: Serial.println(17); break;
case LTR390_RESOLUTION_18BIT: Serial.println(18); break;
case LTR390_RESOLUTION_19BIT: Serial.println(19); break;
case LTR390_RESOLUTION_20BIT: Serial.println(20); break;
ltr.setThresholds(100, 1000);
ltr.configInterrupt(true, LTR390_MODE_UVS);
if (ltr.newDataAvailable()) {
Serial.print("UV data: ");
Serial.print(ltr.readUVS());
delay(100);
Does anyone know if I'm doing something obviously wrong or is there perhaps some modification I need to make to the Adafruit LTR390 library? I was thinking it would work similar to the SHTC3 in how to configure it but perhaps I'm not understanding something. I strongly want to make this work in the Arduino environment since I'm using other sensors from Adafruit that I already got working in Arduino.
