This is regarding the 64x64 RGB LED Matrix kit (PID:3649) that I purchased from Adafruit.
The order number is #2694790-8342651276.
When I tried connecting the display kit to my microcontroller board and power supply , I found that one half of the board is always completely lit up and displays different colors which can be seen in the screenshot I have attached.
For your reference , I am using a 5V and a 4A power adapter for this kit .
Could you please let me know what could be this issue and how to resolve it?
64x64 RGB LED Matrix - 2.5mm Pitch - 1/32 Scan not working
- sugan_09
- adafruit_support_carter
Re: 64x64 RGB LED Matrix - 2.5mm Pitch - 1/32 Scan not worki
What are you using to drive the matrix display?
- sugan_09
I am using LPC4078 microcontroller to drive the display. I tried to power up the matrix display using 5V 4A power adapter. And observed that the upper half of the display lit up and produced random colors.
- sugan_09
Could you kindly provide solution/updates for this issue?
We don't have any support for usage with a LPC4078. Any form of bare wire connections to the matrix itself are also not recommended or supported:
https://learn.adafruit.com/32x16-32x32- ... mper-wires
Is the LPC4078 the only device you have available to drive the RGB matrix?
