90640 IR camera
- adafruit_support_carter
Re: 90640 IR camera
The setup you mention in your first post, using the MLX90640 camera with the Feather ESP8266, is no longer available?
- alainsam
Re: 90640 IR camera
Like I said it is in a box collecting data, if you insist I will take a picture of it but you won't see the connections that are the same as used during the tests:
wire color connected to
RED 5V
BLACK Ground
YELLOW CLK
BLUE SDA
RED 5V
BLACK Ground
YELLOW CLK
BLUE SDA
Re: 90640 IR camera
Just confused about what has changed since original post which references a Feather ESP8266 and the MLX90640? That hardware is no longer available?
Now we are troubleshooting a Feather ESP32 with an AMG88xx?
- alainsam
Re: 90640 IR camera
No, it is still the 8266 board that did not work with the 90640.
Re: 90640 IR camera
OK, let's get back to figuring out why you can't see anything in the serial monitor, since that will help troubleshooting everything else.
Try running this sketch:
and verify you can open the Serial Monitor and see the expected output:
int count = 0;
Serial.begin(9600);
Serial.print("count = "); Serial.println(count++);
delay(1000);
- alainsam
Re: 90640 IR camera
I changed the USB cable and now the monitor screen shows the counting correctly with your test. And also "magically " it works with the AMG88xx_test. Damn it! I changed the cable before and it was still not working.... Tomorrow I will test again the 90640 with this new cable and let you know the result.
Re: 90640 IR camera
Bad USB cable strikes again :) Glad you figured it out. Amazing how often that unfortunately happens. Can be very frustrating.
OK, report back what happens when you try the MLX90640 again and we'll proceed from there.
- alainsam
Re: 90640 IR camera
I still get a blank screen on the monitor with the 8266 and the 90640 camera: I made sure that I have the working USB cable.
Is it possible that the 8266 doesn't work with this camera?
Re: 90640 IR camera
Should work OK with ESP8266.
Try running this I2C scanner sketch:
https://learn.adafruit.com/scanning-i2c ... es/arduino
and verify you can at least see the MLX90640's address:
- alainsam
Re: 90640 IR camera
Scanning...
I2C device found at address 0x33 !
done
Scanning...
done
This work...
done
Scanning...
done
This work...
- alainsam
Re: 90640 IR camera
It works with the test that you asked me to run but it still doesn't work with the camera. Note that I tested the camera with an ESP32 and that works...
Re: 90640 IR camera
OK, something does seem to be happening with ESP8266. This used to work, so not sure what has changed. I did some testing and was able to get the issue down to a simple example sketch and opened an issue here:
https://github.com/adafruit/Adafruit_MLX90640/issues/2
- alainsam
Re: 90640 IR camera
Ok, I can send you the board if it can be useful?
Re: 90640 IR camera
Thanks, but it seems like something we are able to recreate here with all the same hardware. So it's not specific to your actual hardware. Should just be a software issue. Keep an eye on that issue thread.
