90640 IR camera
alainsam
90640 IR camera
Post by alainsam »
I just bought this IR camera and trying to test it with the example on arduino IDE: MLX90640_simpletest
I use the Feather HUZZAH with ESP8266 With Headers and connect the sensor with I2C with STEMMA
The sketch seems to compile without problem but there is no output on the serial monitor,it seems that the serial output is "frozen"
Any idea?
Attached File: Compiler output
90640simpleOutput.txt
(63.11 KiB) Downloaded 8 times
adafruit_support_carter
Re: 90640 IR camera
You don't even see
Adafruit MLX90640 Simple Test
printed in the serial monitor?
That's the first thing that gets printed and doesn't require anything special from the MLX:
https://github.com/adafruit/Adafruit_ML ... st.ino#L15
alainsam
Re: 90640 IR camera
Post by alainsam »
Nope - Nothing!...
sj_remington
Re: 90640 IR camera
Post by sj_remington »
Check the serial monitor baud rate. It should match the Serial.begin() baud rate.
alainsam
Re: 90640 IR camera
Post by alainsam »
Yes, that was the first thing I did, I also changed the USB cable and verified all connections to the camera. I also tested the output with the basic examples: Blink and ASCII tables display on the monitor. All worked fine...
sj_remington
Re: 90640 IR camera
Disconnect the sensor completely and run the program again. If it doesn't print, the problem is not in the sensor.
Printing is the first thing the program does, and that is independent of sensor presence.
  while (!Serial) delay(10);
  Serial.begin(115200);
  delay(100);
  Serial.println("Adafruit MLX90640 Simple Test");
Re: 90640 IR camera
Yah, if you aren't seeing that first print in the Serial Monitor, then something else is happening. Try and figure out why you can't see the serial prints. It sounds like it's at least working for other examples?
alainsam
Re: 90640 IR camera
Post by alainsam »
I disconnected the camera resulting also in no output on the monitor after running the program.
Attached is the Tool settings
One thing I remarked when trying to upload the 90640 library for update: It asks for a long list of dependencies: There is none of them in my library folder and I don't see the use of these. Can you comment?
Re: 90640 IR camera
If you install via Library Manager, it should take care of installing the dependencies.
If you are missing any necessary dependency, then you shouldn't even be able to compile the example. But you mention it compiles OK in your first post. So it seems like you have the required libraries. The dependencies can chain and thus the resulting list of everything (your photo) can be long. Those are the libraries needed for *everything* in the MLX90640 library, including all example sketches.
alainsam
Re: 90640 IR camera
Post by alainsam »
Ah! I now have the following printed on the monitor:
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00043350
~ld
I think that some error from the ESP- I am not familiar with that not being ESP savy What should I do to correct it?
alainsam
Re: 90640 IR camera
Post by alainsam »
Can somebody help me with this? I am really stuck...
Re: 90640 IR camera
Backup and verify that you can at least successfully upload the basic Blink example:
https://learn.adafruit.com/adafruit-fea ... 2720758-28
alainsam
Re: 90640 IR camera
Post by alainsam »
Yes the BLINK test works...
I have an AMG88xx: I am able to load the test but when it is running, nothing shows on the Monitor like for the 90640 IR..I really think that my Feather8266 has a defect. Can I have an RMA for it can not be fixed?
Re: 90640 IR camera
If you can load and run a blink example, then the board is generally OK.
Please post a photo showing how you are connecting the IR camera to the Feather.
alainsam
Re: 90640 IR camera
Post by alainsam »
Can't post the setting of the 90640 now as I am using it within a closed box with an ESP32 All the connections and software are the same, except for ESP32, and it works... So I definitively think that the ESP8266 has a problem.
Here is the photo with the sketch test for AMG88xx plugged into the ESP8266 I have the same problem: No output on the monitor...
