Adafruit_VL53L1X Setting new I2C address
IndigoLand
Post by IndigoLand »
I've recently purchased two Adafruit_VL53L1X sensors and I would like them to work both at the same time for detecting obstacles.
According to the guidelines, I should reset those two and give them new addresses. When I am coding them on Arduino IDE, I used the lox.setAddress() function as i used for the VL53L0X type and it reported a problem which showed that ​'class Adafruit_VL53L1X' has no member named 'setAddress'
I want to know what is the appropriate sentence for setting new address in the adafruit_VL53L1X library class.
THANKS A LOT!
mikeysklar
Re: Adafruit_VL53L1X Setting new I2C address
Post by mikeysklar »
Did you go through the reset and programming of i2c addresses as suggested in the guide:
For future reference, the default I2C address is 0x29. You can change it, but only in software. That means you have to wire the SHUTDOWN pin and hold all but one sensor in reset while you reconfigure one sensor at a time
https://learn.adafruit.com/adafruit-vl5 ... ut/pinouts
Which version of the library are you running?
I do see setAddress being used as you imply in this libraries example Adafruit_VL6180x v1.3.2 released 2 days ago:
https://github.com/adafruit/Adafruit_VL ... triple.ino
#include <Adafruit_VL6180X.h>
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
#define LOX3_ADDRESS 0x32
// set the pins to shutdown
#define SHT_LOX1 7
#define SHT_LOX2 6
#define SHT_LOX3 5
// Optional define GPIO pins to check to see if complete
#define GPIO_LOX1 4
#define GPIO_LOX2 3
#define GPIO_LOX3 2
#define TIMING_PIN 13
// objects for the VL6180X
Adafruit_VL6180X lox1 = Adafruit_VL6180X();
Adafruit_VL6180X lox2 = Adafruit_VL6180X();
Adafruit_VL6180X lox3 = Adafruit_VL6180X();
// Setup mode for doing reads
typedef enum {RUN_MODE_DEFAULT, RUN_MODE_TIMED, RUN_MODE_ASYNC, RUN_MODE_GPIO, RUN_MODE_CONT} runmode_t;
runmode_t run_mode = RUN_MODE_DEFAULT;
uint8_t show_command_list = 1;
// Define some globals used in the continuous range mode
// Note: going to start table drive this part, may back up and do the rest later
Adafruit_VL6180X *sensors[] = {&lox1, &lox2, &lox3};
const uint8_t COUNT_SENSORS = sizeof(sensors) / sizeof(sensors[0]);
const int sensor_gpios[COUNT_SENSORS] = {GPIO_LOX1, GPIO_LOX2, GPIO_LOX3}; // if any are < 0 will poll instead
uint8_t         sensor_ranges[COUNT_SENSORS];
uint8_t         sensor_status[COUNT_SENSORS];
// Could do with uint8_t for 8 sensors, but just in case...
const uint16_t  ALL_SENSORS_PENDING = ((1 << COUNT_SENSORS) - 1);
uint16_t        sensors_pending = ALL_SENSORS_PENDING;
uint32_t        sensor_last_cycle_time;
    Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
    Keep sensor #1 awake by keeping XSHUT pin high
    Put all other sensors into shutdown by pulling XSHUT pins low
    Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
    Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
    Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
void setID() {
  // all reset
  digitalWrite(SHT_LOX1, LOW);
  digitalWrite(SHT_LOX2, LOW);
  digitalWrite(SHT_LOX3, LOW);
  delay(10);
  // all unreset
  digitalWrite(SHT_LOX1, HIGH);
  digitalWrite(SHT_LOX2, HIGH);
  digitalWrite(SHT_LOX3, HIGH);
  delay(10);
  // activating LOX1 and reseting LOX2
  // initing LOX1
  if (!lox1.begin()) {
    Serial.println(F("Failed to boot first VL6180X"));
    while (1);
  lox1.setAddress(LOX1_ADDRESS);
  delay(10);
  // activating LOX2
  delay(10);
  //initing LOX2
  if (!lox2.begin()) {
    Serial.println(F("Failed to boot second VL6180X"));
    while (1);
  lox2.setAddress(LOX2_ADDRESS);
  // activating LOX3
  delay(10);
  //initing LOX3
  if (!lox3.begin()) {
    Serial.println(F("Failed to boot third VL6180X"));
    while (1);
  lox3.setAddress(LOX3_ADDRESS);
void readSensor(Adafruit_VL6180X &vl) {
  Serial.print(" Addr: ");
  Serial.print(vl.getAddress(), HEX);
  float lux = vl.readLux(VL6180X_ALS_GAIN_5);
  Serial.print(" Lux: "); Serial.print(lux);
  uint8_t range = vl.readRange();
  uint8_t status = vl.readRangeStatus();
  if (status == VL6180X_ERROR_NONE) {
    Serial.print(" Range: "); Serial.print(range);
  // Some error occurred, print it out!
  if  ((status >= VL6180X_ERROR_SYSERR_1) && (status <= VL6180X_ERROR_SYSERR_5)) {
    Serial.print("(System error)");
  else if (status == VL6180X_ERROR_ECEFAIL) {
    Serial.print("(ECE failure)");
  else if (status == VL6180X_ERROR_NOCONVERGE) {
    Serial.print("(No convergence)");
  else if (status == VL6180X_ERROR_RANGEIGNORE) {
    Serial.print("(Ignoring range)");
  else if (status == VL6180X_ERROR_SNR) {
    Serial.print("Signal/Noise error");
  else if (status == VL6180X_ERROR_RAWUFLOW) {
    Serial.print("Raw reading underflow");
  else if (status == VL6180X_ERROR_RAWOFLOW) {
    Serial.print("Raw reading overflow");
  else if (status == VL6180X_ERROR_RANGEUFLOW) {
    Serial.print("Range reading underflow");
  else if (status == VL6180X_ERROR_RANGEOFLOW) {
    Serial.print("Range reading overflow");
void read_sensors() {
  readSensor(lox1);
  readSensor(lox2);
  readSensor(lox3);
  Serial.println();
void timed_read_sensors() {
  digitalWrite(TIMING_PIN, HIGH);
  uint32_t start_time = millis();
  uint8_t range_lox1 = lox1.readRange();
  uint8_t status_lox1 = lox1.readRangeStatus();
  uint8_t range_lox2 = lox2.readRange();
  uint8_t status_lox2 = lox2.readRangeStatus();
  uint8_t range_lox3 = lox3.readRange();
  uint8_t status_lox3 = lox3.readRangeStatus();
  uint32_t delta_time = millis() - start_time;
  digitalWrite(TIMING_PIN, LOW);
  Serial.print(delta_time, DEC);
  Serial.print(" : ");
  if (status_lox1 == VL6180X_ERROR_NONE) Serial.print(range_lox1, DEC);
  else Serial.print("###");
  if (status_lox2 == VL6180X_ERROR_NONE) Serial.print(range_lox2, DEC);
  if (status_lox3 == VL6180X_ERROR_NONE) Serial.print(range_lox3, DEC);
  Serial.println();
void timed_async_read_sensors() {
  // lets start up all three
  lox1.startRange();
  lox2.startRange();
  lox3.startRange();
  // wait for each of them to complete
  lox1.waitRangeComplete();
  lox2.waitRangeComplete();
  lox3.waitRangeComplete();
  uint8_t range_lox1 = lox1.readRangeResult();
  uint8_t range_lox2 = lox2.readRangeResult();
  uint8_t range_lox3 = lox3.readRangeResult();
  Serial.println();
void timed_async_read_gpio() {
#ifdef GPIO_LOX1
  uint8_t range_lox1 = 0;
  uint8_t status_lox1 = VL6180X_ERROR_NONE;
  uint8_t range_lox2 = 0;
  uint8_t status_lox2 = VL6180X_ERROR_NONE;
  uint8_t range_lox3 = 0;
  uint8_t status_lox3 = VL6180X_ERROR_NONE;
  uint8_t pending_sensors = 0x7;
  lox1.startRange();
  lox2.startRange();
  lox3.startRange();
  while (pending_sensors && ((millis() - start_time) < 1000)) {
    if ((pending_sensors & 0x1) && !digitalRead(GPIO_LOX1)) {
      pending_sensors ^= 0x1;
    if ((pending_sensors & 0x2) && !digitalRead(GPIO_LOX2)) {
      pending_sensors ^= 0x2;
    if ((pending_sensors & 0x4) && !digitalRead(GPIO_LOX3)) {
      pending_sensors ^= 0x4;
  Serial.print("(");
  Serial.print(pending_sensors, DEC);
  Serial.print(") : ");
  Serial.println();
#endif
// Continuous range test code
void start_continuous_range() {
  Serial.println("start Continuous range mode");
  for (uint8_t i = 0; i < COUNT_SENSORS; i++) {
    sensors[i]->startRangeContinuous();
  sensor_last_cycle_time = millis();
void stop_continuous_range() {
  Serial.println("Stop Continuous range mode");
    sensors[i]->stopRangeContinuous();
  delay(100); // give time for it to complete.
void Process_continuous_range() {
  uint16_t mask = 1;
    bool range_complete = false;
    if (sensors_pending & mask) {
      if (sensor_gpios[i] >= 0)
        range_complete = !digitalRead(sensor_gpios[i]);
      else
        range_complete = sensors[i]->isRangeComplete();
      if (range_complete) {
        sensor_ranges[i] = sensors[i]->readRangeResult();
        sensor_status[i] = sensors[i]->readRangeStatus();
        sensors_pending ^= mask;
    mask <<= 1; // setup to test next one
  // See if we have all of our sensors read OK
  uint32_t delta_time = millis() - sensor_last_cycle_time;
  if (!sensors_pending || (delta_time > 1000)) {
    Serial.print("(");
    Serial.print(sensors_pending, HEX);
    Serial.print(")");
    mask = 1;
      if (sensors_pending & mask) Serial.print("TTT");  // show timeout in this one
      else if (sensor_status[i] == VL6180X_ERROR_NONE) Serial.print(sensor_ranges[i], DEC);
      else {
        Serial.print("#");
        Serial.print(sensor_status[i], DEC);
    // setup for next pass
    Serial.println();
// Setup
  Serial.begin(115200);
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  pinMode(SHT_LOX1, OUTPUT);
  pinMode(SHT_LOX2, OUTPUT);
  pinMode(SHT_LOX3, OUTPUT);
  // Enable timing pin so easy to see when pass starts and ends
  pinMode(TIMING_PIN, OUTPUT);
#ifdef GPIO_LOX1
  // If we defined GPIO pins, enable them as PULL UP
  pinMode(GPIO_LOX1, INPUT_PULLUP);
  pinMode(GPIO_LOX2, INPUT_PULLUP);
  pinMode(GPIO_LOX3, INPUT_PULLUP);
#endif
  Serial.println("Shutdown pins inited...");
  Serial.println("All in reset mode...(pins are low)");
  Serial.println("Starting...");
  setID();
// Loop
  if (Serial.available()) {
    uint8_t ch = Serial.read();
    while (Serial.read() != -1) ; // remove the rest
    runmode_t prev_run_mode = run_mode;
    // See what the user typed in
    switch (ch) {
      case 'd':
      case 'D':
        break;
      case 't':
      case 'T':
        run_mode = RUN_MODE_TIMED;
        break;
      case 'a':
      case 'A':
        run_mode = RUN_MODE_ASYNC;
        break;
#ifdef GPIO_LOX1
      case 'g':
      case 'G':
        run_mode = RUN_MODE_GPIO;
        break;
#endif
      case 'c':
      case 'C':
        run_mode = RUN_MODE_CONT;
        break;
      default:
    if (run_mode != prev_run_mode) {
      // if previous mode was continuous mode, shut it down
      if (prev_run_mode == RUN_MODE_CONT) stop_continuous_range();
      if (run_mode == RUN_MODE_CONT) start_continuous_range();
  if (show_command_list) {
    Serial.println("\nSet run mode by entering one of the following letters");
    Serial.println("    D - Default mode");
    Serial.println("    T - Timed mode - Reads done one after another");
    Serial.println("    A - Asynchronous mode - Try starting all three at once");
#ifdef GPIO_LOX1
    Serial.println("    G - Asynchronous mode - Like above use GPIO pins");
#endif
    Serial.println("    C - Continuous mode - Try starting all three at once");
    show_command_list = 0;
  switch (run_mode) {
    case RUN_MODE_DEFAULT:
      read_sensors();
      break;
    case RUN_MODE_TIMED:
      timed_read_sensors();
      break;
    case RUN_MODE_ASYNC:
      timed_async_read_sensors();
      break;
    case RUN_MODE_GPIO:
      timed_async_read_gpio();
      break;
    case RUN_MODE_CONT:
      Process_continuous_range();
  delay(100);
IndigoLand
mikeysklar wrote:Did you go through the reset and programming of i2c addresses as suggested in the guide:
#define SHT_LOX1 7
#define SHT_LOX2 6
#define SHT_LOX3 5
#define GPIO_LOX1 4
#define GPIO_LOX2 3
#define GPIO_LOX3 2
void setID() {
  // all reset
  delay(10);
  // all unreset
  delay(10);
  // initing LOX1
    while (1);
  delay(10);
  // activating LOX2
  delay(10);
  //initing LOX2
    while (1);
  // activating LOX3
  delay(10);
  //initing LOX3
    while (1);
  readSensor(lox1);
  readSensor(lox2);
  readSensor(lox3);
  Serial.println();
  Serial.println();
  lox1.startRange();
  lox2.startRange();
  lox3.startRange();
  Serial.println();
#ifdef GPIO_LOX1
  lox1.startRange();
  lox2.startRange();
  lox3.startRange();
  Serial.print("(");
  Serial.println();
#endif
  uint16_t mask = 1;
      else
    Serial.print("(");
    Serial.print(")");
    mask = 1;
      else {
        Serial.print("#");
    Serial.println();
// Setup
  while (! Serial) {
    delay(1);
#ifdef GPIO_LOX1
#endif
  setID();
// Loop
    switch (ch) {
      case 'd':
      case 'D':
        break;
      case 't':
      case 'T':
        break;
      case 'a':
      case 'A':
        break;
#ifdef GPIO_LOX1
      case 'g':
      case 'G':
        break;
#endif
      case 'c':
      case 'C':
        break;
      default:
#ifdef GPIO_LOX1
#endif
  switch (run_mode) {
      read_sensors();
      break;
      break;
      break;
    case RUN_MODE_GPIO:
      break;
    case RUN_MODE_CONT:
  delay(100);
I am using the VL53L1X library ver3.0 and I have also seen the VL6180X but can I use that template for setting Adafruit VL53L1X?
Or you can provide me a template for multiple use of Adafruit VL53L1X sensors since the library only provides one template for a single sensor.
I have tried wiring the Shutdown pins and reset them but it still doesnt work..
If you can provide me with any advice I will be grateful
mikeysklar
The version number of your library does not match ours.
Our Adafruit_VL53L1X is currently at 1.1.2 updated last on Oct. 25th 2021.
https://github.com/adafruit/Adafruit_VL53L0X
