OK, I am not as comfortable as I once was around a soldering Iron, but I was asked(Pestered) by my wife to build/bash/make a CO2 Sensor...
So, came here and found this : https://www.adafruit.com/product/4867?g ... hYQAvD_BwE
Looks perfect, I want to order one... But holdonasec... It seems to be the case that ONLY the sensor is the item for sale. Not a problem... But WHAT is the other part (The readout)
I would like that too, to complete the product as shown, but I can't figure out WHAT it is/What to buy
Help?
CO2 Sensor component not described
- adafruit_support_carter
Re: CO2 Sensor component not described
There are actually two things here:
https://www.adafruit.com/product/4650
The second item, which is sitting underneath the display, would be a Feather main board. Not sure which exact one is used in the product demo, but there are lots of choices. This is what is actually running the code that is talking to the sensor and updating the display.
This guide has a good overview of what Feather (main boards) and FeatherWings (accessory add boards) are:
https://learn.adafruit.com/adafruit-feather
The display that you see in the photo is this FeatherWing:https://www.adafruit.com/product/4650
- everseeker
Thank you very much. I WISH I had seen this before this morning... You had a sale on Feathers... Oh Well.
So, a valid parts list might be:
Assembled Feather HUZZAH w/ ESP8266 WiFi With Stacking Headers
Adafruit SCD-30 - NDIR CO2 Temperature and Humidity Sensor - STEMMA QT / Qwiic PID: 4867
Adafruit FeatherWing OLED - 128x64 OLED Add-on For Feather - STEMMA QT / Qwiic PID: 4650
Correct?
Correct?
That looks generally correct. The one other item would be the little cable between the TFT and the SCD30. That's one of these:
https://www.adafruit.com/product/4210
Note the cable comes in various lengths. Linking to 100mm, as that appears to be what is shown in photo. But you could use a different length if you wanted.
EDIT - just to mention, an ESP8266 based board would be Arduino only. If you wanted to use CircuitPython, checkout the various Feather options here:
https://circuitpython.org/downloads
