Inky Phat display not working out of the box
chasehunter
Post by chasehunter »
I received order # 2718259-0989888092. I wrote a new image of Raspberry Pi OS to the SD card.
I powered on my Pi Zero W using a 5.2v power supply and connected via VNC.
From there simply followed the tutorial by Pimoroni https://learn.pimoroni.com/article/gett ... -inky-phat
When attempting to run their 'name-badge.py' example I get the error shown in the screenshot below.
Screen Shot 2021-11-24 at 6.37.47 PM.png (577.89 KiB) Viewed 280 times
I attempted disconnecting and reattaching the inky phat, but unfortunately to no avail.
chasehunter
Re: Inky Phat display not working out of the box
UPDATE: I ordered an additional black/white inkyphat. I also order a yellow inkyphat to see if I could get the issue resolved. I am still having the same problem. Below is the exact error message
python3 name-badge.py -t "phat" -c "yellow" -n "Chase Hunter"
Error:
Inky pHAT/wHAT: Hello... my name is:
Use Inky pHAT/wHAT as a personalised name badge!
Failed to detect an Inky board, you must specify the type and colour manually.
