good morning.i would like to buy some adafruit components in other to make a motion capture suit.
my needs are following.
BOARD MCU MEGA2560 reference 1050-1018-ND
[img][img][/img][/img]
BNO055 XPLAINED PRO EVAL KIT reference: ATBNO055-XPRO-ND
ASSEMBLED DATA LOGGING SHIELD reference: 1528-1044-ND
TCA9548A I2C MULTIPLEXER BOARD reference: 1528-1363-ND
RJ45 BREAKOUT reference: 1568-1097-ND
.how much does each componet cost?
regards
sensor BNO055 ; multiplexer-I2C needed
- diymocap
- Attachments
- 1050-1018-ND
- Mega-2560-(the-brain).jpg (424.09 KiB) Viewed 349 times
- 1528-1363-ND
- Adafruit-I2C-multiplexer board.jpg (154.37 KiB) Viewed 349 times
- ATBNO055-XPRO-ND
- IMU-(inertial-measurement-Unit).jpg (311.63 KiB) Viewed 349 times
- adafruit_support_bill
Re: sensor BNO055 ; multiplexer-I2C needed
The part numbers you list are DigiKey part numbers. And only two of those products are from Adafruit. You can find the DiggiKey prices on the DigiKey site.
Our price for the Adafruit Data Logger Shield is $13.95 https://www.adafruit.com/product/1141
And the TCA9548A I2C multiplexer is $6.95 https://www.adafruit.com/product/2717
Our version of the BNO055 breakout board is $19.95 https://www.adafruit.com/product/4646
We do not have a Mega 2650 equivalent, but our Grand Central has the same form-factor and uses an ATSAMD51 M4 processor which significantly more powerful than the Atmega 2560. It sells for $37.50 https://www.adafruit.com/product/4064
- Claude_J_Greengrass
Hi diymocap
From this post and your previous post, it would appear we have a common interest in the measurement of body movements and have similar problems. I’m trying to measure tremors in the hand/arm. My solution to the component problem is:
I started with an R3 Uno but quickly exhausted the 2k memory. Switched to an ELEGOO MEGA R3 Board ATmega 2560 I purchased from Amazon.
https://www.amazon.com/gp/product/B01H4 ... =UTF8&th=1
For data logging I used SD Card Shield V4 https://www.seeedstudio.com/SD-Card-Shi ... -1381.html
You can use the ExFatFormatter with the above combo. I haven’t yet had time to try it with the BNO085 sensor. I chose this sensor over the BNO055 as I had read of some problems with the BNO055 on this and other forums. So far I have a single Adafruit LSM6DS33 sensor working and recording in this configuration. It allows me to sample and record 6 DOF at 250Hz which is the fastest sample rate I could get the Mega to handle. Depending on the number of sensors, the Mega may not be fast enough. I expect whenI get my SensorGlove together with measurements of the 7 DOF of the hand/arm and 2 more 3-Axis sensors for a finger and thumb, I will have to switch processors to an Arm or similar processor. YMMV
My choice for a multiplexer is: SparkFun Qwiic Mux Breakout - 8 Channel (TCA9548A) https://www.sparkfun.com/products/16784
Since you have already asked about the I2C cable length in a separate post, I won’t bother with those components.
I would be interested is hearing more about your project either here or offline.
AMA
AMA
I just found this: SlimeVR Full-Body Tracker https://www.crowdsupply.com/slimevr/sli ... dy-tracker
I may be a simple answer to your problem at a larger $ cost.
- diymocap
all of you thank you for your reply.theses were components i need to build this
https://www.youtube.com/watch?v=FGNmMZX0g_M
Claude_J_Greengrass i wouls appreciate to collaborate with you.
regards
regards
- diymocap
i also need BREAKOUT BOARD LM3671 3.3V.
how much does it cost?
i would also use to know which component can replace BNO055 (since it is finished)?
regards
regards
https://www.adafruit.com/product/2745
The older style BNO055 are in-stock: https://www.adafruit.com/product/2472
The BNO085 has improved firmware. Unfortunately, we are out of stock on these at the moment: https://www.adafruit.com/product/4754
Briefly, my interest in a motion capture suit is to measure tremors. Either Essential Tremors or Parkinson's. Also with Parkinson's, gait measurements are very helpful.diymocap wrote:all of you thank you for your reply.theses were components i need to build this
regards
Aside from the obvious use, what do you intend to do with the motion capture suit once you get it working?
- diymocap
good morning Claude.I would like to make animated short film with these data.
the data will be recorded in bvh format in my software (blender).then those data will be bound to a new character.and finaly you will have character like avatar or monster speaking.
regards
regards
- diymocap
i am still waiting for the prices and availability ofadafruit_support_bill wrote:https://www.adafruit.com/product/2745
regards
The link was posted above. You can also easily search for products by name or part number in the store: https://www.adafruit.com/
- diymocap
it is this ?adafruit_support_bill wrote:The link was posted above. You can also easily search for products by name or part number in the store: https://www.adafruit.com/
https://www.adafruit.com/?q=LM3671+&sort=BestMatch
- diymocap
excuse me bill.i would use to know what are the differences between those 02 products.
and
https://www.digikey.com/en/products/det ... QBEQBdAXyA.
regards
and
regards
Both are breakout boards for the BNO055. The one in our store is our design for a general purpose breakout board. The one in the DigiKey store is from Atmel/Microchip and appears to be designed to plug into their development systems.
Either one would probably work for your application. Although the Atmel/Microchip board is a bit bulkier and has a 40 week lead time from DigiKey.
