MPRLS Ported Pressure Sensor
eklinger715
Post by eklinger715 »
Hello
Can you please share the current consumption and quiescent current for the MPRLS Ported Pressure Sensor board?
Thank you!
mikeysklar
Re: MPRLS Ported Pressure Sensor
Post by mikeysklar »
There are more details in the datasheet, but here is a the high level summary.
Screen Shot 2021-11-30 at 2.05.43 PM.png (28.28 KiB) Viewed 126 times
https://sensing.honeywell.com/honeywell ... 628-en.pdf
eklinger715
That’s for the pressure sensor only not the entire circuit right? This won’t include the current consumption of the voltage regulator for example which is what I need.
mikeysklar
Yes, this is for the sensor only. I do not have actual electrical characteristics for the full MPRLS breakout board.
You can estimate the combined effect of the MPRLS sensor + voltage regulator (MIC5225). Attached are the electrical characteristics for the MIC5225 voltage regulator used on this breakout board.
Screen Shot 2021-12-01 at 1.26.41 PM.png (203.84 KiB) Viewed 111 times
