putting PMS5003 into "passive" mode
- earthres
I am using the Adafruit library for getting particulate data from your PMS5003. As I understand it, this sensor has an "active" mode that sends a data stream about once per second, and a "passive" mode that sends data only on request. The "active" mode is the default mode, as implemented in the sample code with the library. (right?) Do you have an example code that puts the PMS5003 in "passive" mode and sends a data stream only on request?
- mikeysklar
Re: putting PMS5003 into "passive" mode
@earthres,
There is a chunk of code using passive mode in an issue here using the pms5003 library.
https://github.com/jbanaszczyk/pms5003/issues/8
This looks like the juicy bit...Full code below...Keep in mind it's from an old issue.
pms.write(Pmsx003::cmdModePassive);
#include <Arduino.h>
#include <pms.h>
Pmsx003 pms(D6, D7); //Wemos RX-D7, TX-D6
void setup(void) {
Serial.begin(115200);
while (!Serial) {};
Serial.println("Pmsx003");
pms.begin();
//pms.waitForData(Pmsx003::wakeupTime);
//pms.write(Pmsx003::cmdModeActive);
//pms.write(Pmsx003::cmdModePassive);
auto lastRead = millis();
void loop(void) {
delay(30000);
pms.write(Pmsx003::cmdWakeup);
delay(30000);
const auto n = Pmsx003::Reserved;
Pmsx003::pmsData data[n];
Pmsx003::PmsStatus status = pms.read(data, n);
switch (status) {
case Pmsx003::OK:
Serial.println("_________________");
auto newRead = millis();
Serial.print("Wait time ");
Serial.println(newRead - lastRead);
lastRead = newRead;
// For loop starts from 3
// Skip the first three data (PM1dot0CF1, PM2dot5CF1, PM10CF1)
for (size_t i = Pmsx003::PM1dot0; i < n; ++i) {
Serial.print(data[i]);
Serial.print("\t");
Serial.print(Pmsx003::dataNames[i]);
Serial.print(" [");
Serial.print(Pmsx003::metrics[i]);
Serial.print("]");
Serial.println();
break;
case Pmsx003::noData:
break;
default:
Serial.println(Pmsx003::errorMsg[status]);
//pms.write(Pmsx003::cmdSleep);
