hey all!
Im tring to set up my new Adafruit Audio FX soundboard connected to My arduino mega 2560 and Ive installed the adafruint example for it and i ... think.. i have it hooked up right.. But when i looking at the serial monitor all i get is "Adafruit Sound Board! Not found" please help.
Adafruit Audio FX soundboard "NOT FOUND"
- jartog
- Attachments
- 268687505_499931408168287_8037008691661203547_n.jpg (134.24 KiB) Viewed 452 times
- jartog
Re: Adafruit Audio FX soundboard "NOT FOUND"
here is the close up
- Attachments
- 269039443_345994980198889_4892937390066497059_n.jpg (133.04 KiB) Viewed 451 times
- jartog
and my screen
- Attachments
- 269220422_824772835586572_1891049627380177542_n.jpg (71.86 KiB) Viewed 451 times
- jartog
here is where its plugged in on the board
- Attachments
- 268840061_185112437103830_6392261456065009199_n.jpg (141.49 KiB) Viewed 451 times
- jartog
Any adafruit admins want to let me know what im doing wrong here?
- jartog
Still hoping for an Adafruit employee to help out..? Does anyone know if there is a help line for this stuff?
- Backpassage
Try and send an email to [email protected] and add a link to your post so they can see it... Good luck... :)
- adafruit_support_carter
The Mega has pin restrictions on RX when using soft serial.
https://www.arduino.cc/en/Reference/softwareSerial
Try changing to one of those instead of 6.Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
- jartog
awesome thanks a bunch ill try that
- jartog
Unfortunately after changing my transmit to pin 13 and changing it on the code. I still am having the same issue.
- jartog
When I open serial monitor I do hear was sounds like it maybe be resetting or something i head small pop in the speakers
Did you update your code to match the new pins being used?
Is it still saying "NOT FOUND"?
- jartog
So i did change it to pin 10 and i changed it in the code as well. Is there only one spot to change it on there it looks like? Still says not found
