I used the I2C address example code from one of the learn guides, i dont remember which to observe the addresses changing.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.12.18 19:19:07 =~=~=~=~=~=~=~=~=~=~=~=
2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x15', '0x17', '0x18', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f', '0x67']
I2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x11', '0x13', '0x14', '0x15', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f', '0x71']
I2C addresses found: ['0x8', '0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x28', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x20', '0x21', '0x23', '0x24', '0x25', '0x27', '0x29', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x8', '0x9', '0xb', '0xc', '0xd', '0xf', '0x10', '0x11', '0x13', '0x14', '0x15', '0x17', '0x19', '0x1b', '0x1c', '0x1d', '0x1f', '0x21', '0x23', '0x24', '0x25', '0x27', '0x2b', '0x2c', '0x2d', '0x2f', '0x30', '0x31', '0x33', '0x34', '0x35', '0x37', '0x39', '0x3b', '0x3c', '0x3d', '0x3f']
I2C addresses found: ['0x8', '0x9', '0xa', '0xb', '0xc', '0xd', '0xe', '0xf', '0x10', '0x11', '0x12', '0x13', '0x14', '0x15', '0x16', '0x17', '0x18', '0x19', '0x1a', '0x1b', '0x1c', '0x1d', '0x1e', '0x1f', '0x20', '0x21', '0x22', '0x23', '0x24', '0x25', '0x26', '0x27', '0x28', '0x29', '0x2a', '0x2b', '0x2c', '0x2d', '0x2e', '0x2f', '0x30', '0x31', '0x32', '0x33', '0x34', '0x35', '0x36', '0x37', '0x38', '0x3a', '0x3b', '0x3c', '0x3d', '0x3e', '0x3f']
I2C addresses found: ['0x9', '0xa', '0xb', '0xe', '0xf', '0x12', '0x13', '0x14', '0x15', '0x18', '0x19', '0x1a', '0x1f', '0x20', '0x21', '0x22', '0x24', '0x25', '0x26', '0x28', '0x29', '0x2a', '0x2b', '0x2c', '0x2d', '0x2e', '0x2f', '0x30', '0x31', '0x32', '0x33', '0x35', '0x38', '0x3c', '0x3d', '0x3e', '0x3f', '0x48']
I2C addresses found: ['0x30']
I2C addresses found: []
I2C addresses found: ['0x31']
I2C addresses found: ['0x8', '0x9', '0xa', '0xb', '0xc', '0xd', '0xe', '0xf', '0x10', '0x11', '0x12', '0x13', '0x14', '0x15', '0x16', '0x17', '0x18', '0x19', '0x1a', '0x1b', '0x1c', '0x1d', '0x1e', '0x1f', '0x20', '0x21', '0x22', '0x23', '0x24', '0x25', '0x26', '0x27', '0x28', '0x29', '0x2a', '0x2b', '0x2c', '0x2d', '0x2e', '0x2f', '0x30', '0x31', '0x32', '0x33', '0x34', '0x35', '0x36', '0x37', '0x38', '0x39', '0x3a', '0x3b', '0x3c', '0x3d', '0x3e', '0x3f']
I2C addresses found: ['0x8', '0x9', '0xa', '0xb', '0xc', '0xd', '0xe', '0xf', '0x10', '0x11', '0x12', '0x13', '0x14', '0x15', '0x16', '0x17', '0x18', '0x19', '0x1a', '0x1c', '0x1d', '0x1e', '0x1f', '0x20', '0x21', '0x22', '0x23', '0x24', '0x25', '0x26', '0x27', '0x28', '0x29', '0x2a', '0x2b', '0x2c', '0x2d', '0x2e', '0x2f', '0x30', '0x31', '0x32', '0x33', '0x34', '0x35', '0x36', '0x37', '0x38', '0x39', '0x3a', '0x3b', '0x3c', '0x3d', '0x3e', '0x3f']
I2C addresses found: ['0x48']
Adafruit CircuitPython 7.1.0-beta.3 on 2021-12-13; Adafruit PyPortal Titano with samd51j20
soft reboot
I have another issue with one of those two different sliders then the originals, where unless the slider is at one extreme or the other, its value bobbles up and down +-3, to deal with it for now i basically had to add a deadzone, but the other slider paired with it doesn't have this issue.
