Purchased a PowerBoost 1000 Basic and 6600mAh battery and connected as shown in the example on the PowerBoost 1000 Basic product page. Charged battery using the bq24074 until the charge light was off. Plugged battery to the PowerBoost and the Low light blinks very dim briefly and Pwr never comes on. If I use the Load Out connection from the bq24074 and connect that to the PowerBoost, both Low and Pwr light and the PowerBoost gets very hot then both lights start blinking.
Is it possible the PowerBoost is defective?
PowerBoost 1000 Basic, defective?
- sigwx
Re: PowerBoost 1000 Basic, defective?
I tried a few more times, and now the light just don't come on. Guessing its no longer working.
- adafruit_support_carter
Please link to product page for battery being used.
- sigwx
Hi, battery used is https://www.adafruit.com/product/353
- sigwx
And I was also trying the Load output from https://www.adafruit.com/product/4755
- adafruit2
how long were your wires?
- sigwx
Well, the battery just connected direct with the cables it came with, those are 4" long. When connecting Load those were 4.5" long
- adafruit2
ok we can replace the PB this one time, emails support@adafruit with a link to this thread & keep the wires are short as possible :)
- sigwx
Ok, but for future reference what about the wire length would cause the device to overheat?
- adafruit2
the wire acts as an inductor, which caused a spike that damaged the booster so keep it as short as possible, 2 inches or less
- sigwx
Interesting so does that mean the example in the product listing needs an update? I just plugged things in the same way as shown.
- adafruit2
we're not sure why, some folks just need shorter wires... it could have to do with initial loading or setup!
- sigwx
Just curious since that would mean I need to cut the wires and reattach the connector on the battery since they are approx 4" from Adafruit
