Adafruit MacroPad RP2040 no buzzer sound
snappawapa
Post by snappawapa »
Hey all! I hope this is in the right place in the forum.
I recently got myself one of these: https://learn.adafruit.com/adafruit-mac ... 40/arduino and am programming it with Arduino. I can upload new sketches just fine, but when I uncomment the speaker code in the setup() function, no sound is produced from the board. I have also tried adding a tone call to the loop() when the encoder button is pressed, but no luck there either. Any ideas?
Thanks in advance!
snappawapa
Re: Adafruit MacroPad RP2040 no buzzer sound
Realized I wasn't clear what code I am using. I am referencing the demo code on the page linked.
adafruit_support_carter
You'll need to also enable the speaker by setting PIN_SPEAKER_ENABLE to HIGH.
  pinMode(PIN_SPEAKER_ENABLE, OUTPUT);
  digitalWrite(PIN_SPEAKER_ENABLE, HIGH);
snappawapa
That did it! Should probably be added to the test code, so other's don't get tripped up like I did :)
