Hi I have a SRC022-12, I would like to separate power and control signals within the slips ring. Can you please confirm that the entries in the spec table "Lead colour code" equate to the ring placement along the shaft of the slip ring? I.e slip ring 1 is connected to the red wire, 2 is next to 1 and is connected to the green wire, etc...
https://cdn-shop.adafruit.com/datasheets/SRC022A-6.pdf
Any thoughts would be much appreciated.
Best regards
Barry M
SRC022-12 internal layout.
- Franklin97355
Re: SRC022-12 internal layout.
The wires are connected to the like-color pigtails. We don't specify what the manufacturer uses internally and don't test other than continuity. Sorry if it is not the product you need.
- CNCModeller
Thanks for the information. Having looked at the part in detail I believe that the rings are connected as I suggested. I'll give it a go. Many thanks again
