Adafruit 1335 Peltier Thermoelectric Cooler Module
- csmigin
I purchased this off eBay and it was delivered January 7. I just tried it out the other day and it appears to be defective. It barely change the temperature around it. Also the resistance isn't accurate. I was hoping to get a replacement product as I spent around USD$33. Let me know what else you need. Thanks!
- sj_remington
Re: Adafruit 1335 Peltier Thermoelectric Cooler Module
Please post a photo of your setup, and post details of the power supply.
Note that if the power supply polarity is chosen such that the hot side is not connected to a heat sink, the module can be destroyed quite quickly.
- csmigin
The power supply is 12v9Ah36w as can be seen in my photo; 25-26ohms of resistance on the cooling plate, and drawing just over one amp.
- sj_remington
What is the voltage of that sealed lead acid battery under load?
The stated module resistance, applied voltage and current draw are inconsistent.
- csmigin
- sj_remington
The module should have resistance of roughly 2 Ohms, as measured by a multimeter, and draw between 5 and 6 Amperes from a 12V source, which would also tend to burn out the inadequate clip leads shown in the photo.
Damage by a reversed connection, leading to overheating, could be consistent with the reported module resistance of 25-26 Ohms.
- csmigin
Nothing was ever hooked up backwards; the leads are plenty strong enough as they are rated for 18 amps as can be seen on this chart). It is a 16 AWG wire. Also I have done this setup before on an identical module and been successful.
